335
Drag row and Drop it to another Table.
Hi Team,
I have a step were in i need to select multiple rows, DRAG them and DROP it to another swftable object.
Is there any properties were in i can perform this operation.
Parents
  • 53790
    Hello Ravindra,
    If I understand well  your scenario, I think that there are no such kind of property, because there are not such kind functionality in our controls. Lets take an example with two UltraGirds and Drag and Drop rows from the first grid into second grid. If you want to achieve this behavior, you should handle few events and write your own code that will do this in your application. If you want to test your drag and drop behavior into your test enviroment, you should duplicate the code from your application into your test enviroment, but I think that this will be more complicated and I`m not sure is it possible.
    Please take a look at the attached video for more details.
    Regards
Reply Children
No Data
