Hi there, I'm currently running on a trial license (of both QTP and TestaAdvantage) so I hope someone can help me quickly!
I am running QTP 9.5 with the .NET add-in; TestAdvantage 2008V1 CLR2, and the application I am testing is written in C# and using NetAdvantage 2008v1 CLR2, so the versions of test and net advantage do matchup.
Here's my problem: I want to be able to retrieve a value from a cell within an UltraWinGrid, when I record a simple click on a cell, QTP records this:
SwfWindow("EMS - Tomi").SwfObject("SwfObject").PaneActivate "Positions"SwfWindow("EMS - Tomi").SwfTable("grid").ActivateRow "10"SwfWindow("EMS - Tomi").SwfTable("grid").ActivateCell "10","Futures"SwfWindow("EMS - Tomi").SwfTable("grid").SelectCell "10","Futures"
When I immediately replay this script, I get an error on the second line (ActivateRow), this error says simply 'General Run Error' and then lists the line in error. Then if I 'skip', the following two lines also throw back the same error. I can seem to access various properties of the grid in a slightly different fashion, for example when I write a script like this (copied from a bit of code that is in one of the samples provided with TestAdvantage):
Dim gridSet grid = SwfWindow("EMS - Tomi").SwfTable("grid").ObjectSet col = grid.DisplayLayout.Bands.getItem(0).Columns.getItem(0)msgbox col
'col' in this case DOES return a value no problems. The only thing is that I am not familiar with the syntax when using the 'Object' method of getting properties, so I don't know if I can access or even set cell properties using this method (The help doesn't seem to provide any examples), and ideally I would like to get to the bottom of why a simple method such as ActivateCell is causing an error.
Does anyone have any ideas?
Many thanks, Ryan.
Did you get a resolution to your issue? We seem to be facing the same problem at our end. During playback if we first play back on a nativ infragistic object we are able to play back on our own application which has inherited controls. If we do not start the playback from nativ infragistics objects then the playback fails.
Kindly let me know if you have any solutions for it.
Malayaj
Hi Ryan,
We are facing identical problem at our end. Did you get to know the solution for it?
If so please pass it on.
Hi Adi,
We are also facing the same issue with TA 2008 V3.
Could you please let us know if you got some answer to your queries?
Hopefully it would help us resolve our issues as well.
We are facing the same issue at our end when we migrated to TA 2008V3.
Did you get any answers to your prayers?
Please share your findings with us.
Hi Mr ammar
Ok fine, I had already emailed them, thanks alot for your cooperation upto now, Will contact you again once things are fixed.
Have a good day
Regards
Adi
