In my application, I need to right click on a read only text and it displays 3 options. I need to verify these 3 options are displayed correctly. The commands to right click are -
SwfWindow("ABC").SwfWindow("XYZ").SwfWindow("MNO").SwfTable("Note").RightClick "0", "0;NoteText"
SwfWindow("ABC").SwfWindow("XYZ").SwfWindow("MNO").SwfTable("Note").SelectMultiple "", "", ""
SwfWindow("ABC").SwfWindow("XYZ").SwfWindow("MNO").SwfTable("Note").SelectRow "0"
After right clicking, if I want to select "Edit" option (one of the 3 options above), the command is -
SwfWindow("ABC").SwfWindow("XYZ").SwfWindow("MNO").SwfTable("Note").WinMenu("ContextMenu").Select "Edit"
But, how can I verify if the option "Edit" is displayed correctly in the right click menu or not?
Rakesh
Let me know if I can be of further assistance.
Thanks for the reply Michael.
Rakesh,
If the WinMenu is not an Infragistics control then TestAdvantage does not come into play. TestAdvantage is designed for testing the Infragistics controls. You will have to work with the developer who built this control.
Hi Michael.
Thanks for responding back. Here are my responses -
1. WinMenu object is descriptive program to select a menu item.It is not an Infragistics control.
2. When i say displayed correctly, i want edit to be displayed as "Edit", but not displayed as "Edti" or "Edit sentence". I am verifying if those 3 options are present correctly as per the requirements.
3. Your sample is close to my AUT.
Thanks!
Hello Rakesh,
We have created a sample that comprises of an ultragrid and a contextmenustrip. When testing I am able to get the following line code similar to match what you have already accomplished.
SwfWindow("MNO").SwfToolbar("contextMenuStrip1").Select "Edit"
Can you please answer the following questions:
1. What is WinMenu object? Is this an Infragistics control?2. Can you clarify your request, 'displayed correctly'? What are you trying to achieve?
As you can tell by my sample, the most QTP will figure out is which item is selected. We are not aware of any other options.
3. Can you verify that our sample (please see below), is closely accurate to your application?
