305
How to use Menu items in QTP for infragistics .net application
I am using:
QTP 9.5 with: TestAdvantage for Windows Forms (HP) Version 2007 Vol. 3 CLR2.0
Application under testing has: NetAdavntage 2007 Vol. 3 CLR 2.0
I am automating an application  where i need to select "Connect" option from file menu. I have written the following code.
   SwfWindow("swfname:=xyz").SwfToolbar("swfname:=xyz").ClickToolbarTool "MenuBar","File"
   wait(2)
   SwfWindow("swfname:=xyz").SwfToolbar("swfnamexyz").ClickMenuTool "MenuBar,File","Connect"
This code works fine normally. But during execution of the script. if user interfare (moves the mouse during Run Time), some times the drop down menu is unable to appear and the script gets failed.
It happens for Context Menus too. When Right clicked at any node of a tree, and then clicking at the Context Menu items, sometimes during Replay, if user moves the mouse pointer then the script fails.
Can any body please suggest me any suitable alternative.
Also note that there is no toolbar buttons for connect and disconnect option  hence i have to use only File menu.
Please help in this as it's an urgent issue.
Nabajyoti
