Using HP UFT11.52 version with Test Advantage 2009 vol 2 which matches with version of Net Advantage. For some of the objects like text fields(SwfEdit, SwfEditor), combo boxes(SwfComboBox), drop downs(SwfList) there is no issues and script runs fine but for SwfTab and SwfButton I get the following general run error message:
Could not load file or assembly 'Infragistics2.Win.v9.2, Version=9.2.20092.1003, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies.The system can not find the file specified.
What could be the issue ?
Hello Pavan,
If you need any additional assistance don’t hesitate to ask.
Regards
Could you please answer to the questions below:
1. What is your OS (Win 7, XP, Windows Server 2008....)2. Are you using (x32) or (x64) bits machine.3. Do you have installed service packs and which one4. Do you have any installed QTP`s patches and which exactly. More details about required patches you could find at: http://ko.infragistics.com/help/supported-environments/5. Are you able to record and replay correct scripts when you are using our default samples that you received with installation of TA6. What is the error message that you received.
