is there any functionality to draw the Min and Max lines against the actual values? (Similar to the picture below)
Thanks.
Hi Harinder,
The Android DataChart currently does not support dashed lines so adding a dashed line for the min/max line is not possible. If you wish to see support for dashed lines added to the Android DataChart in the future, please submit this as a new product idea here: http://ideas.infragistics.com/forums/211526-android
How to make Dashed min max line in android.
Hi Rob,
I needed the same functionality in my app. Are there any possibilities that we can amke the min max lines dashed as available for NUCLiOS.
Hi Elton,
Let me know if you have any further questions on this matter.
The best way to do this would be to create 3 LineSeries and assign them data with a Y value set to where you want the line to be. Your data can be just two data points with the same Y value so the line will display straight horizontally.
I have attached a sample that demonstrates what I mean. Let me know if you have any questions.
