I need to use custom header which contain (CheckBox,TextView) when check the check box on Header all rows should be checked and vise versa
how i can implement this , i can do custom column which has check box all i need custom header and select action to affect on all rows
Hi ueldeep,
I have attached a sample that demonstrates how to provide your own custom content to the Android grid column header. The idea here is that you need to create your own column definition class and override the getHeaderCell method. Inside this method you would create your own custom cell and in turn, this cell would create the content needed to display.
