30
set tooltip property is not being updated
Hello
Im facing a problem, Im trying to update the tooltip of a webimagebutton without success.  I have a webdatagrid, where i have always 2 records, the first one is an editable record, and the other one is a non editable record. So, i have a single button "Edit", which when i select the editable record should say "Edit", and when i select the non editable record, should say "View". Everything works fine, the problem is with the tooltip.
This is the code of the button(by default)
OnClick="m_editButton_Click" ToolTip="Edit selected device configuration.">
As you can see, by default, the text and tooltop refers to "Edit". And this, the javascript function where modifies the button text according selection made
function m_gridAfterRowActivate(gridName, rowId) {
var editButton = ig_getWebControlById("<%=m_editbutton.clientid%>");
if (isDefaultDevice)
editButton.setText('View');
else
editButton.setText('Edit')
As you can see, Im able to modify the Text to "View", once i select to the non editable record and viceversa, but, im not able to do it with tooltip. I was checking the documentation and im only see the setText method available for that purpose.
So, the question is : Is it possible to set the button tooltip according the option selected? Is there any available trick for that?
Thanks in advance for your support.
Kind Regards
  • 11095
    Verified Answer
    Hello Carlos,
    You can use change the title of element.
    document.getElementById("<%=m_editbutton.clientid%>" + "__1").title = 'Desired value';
    Let me know if you need further assistance.
