230
RowUpdating event not firing for ItemTemplate change
I am facing two issues in WebHierarchicalDataGrid.
Issue # 1:
I have a WebHierarchicalDataGrid which has three levels. In each level I have Add. Edit and Delete checkboxes in ItemTemplate(TemplateDataField) for each row. I am expecting that if I check/uncheck any checkbox in any level and press my Save button ultimately RowUpdating event will be called for each edited row whereas this not happening. If I use BoundCheckBoxField instead of ItemTemplate checkboxes it works as expected. Please see ASPX sample code for rest of the details.
The reason to change BoundCheckBoxField to ItemTemplate checkbox field is I have to write javascript code that if my Parent is selected then child checkboxes should be unselected and vice versa. I am not able to get BoundCheckBoxField checkbox in the javascript, it comes as 'undefined' whereas I am able to get the ItemTemplate checkboxes in javascript.
Issue # 2:
In the same above grid when I am using BoundCheckBoxField and try to select Add. Edit, Delete checkboxes then in my RowUpdating event I only get Add checkbox value as "true" rest are coming as false. If I run my code again some time I got correct checkbox value and some time not. Please C# code.
ASPX Code:
<ig:WebHierarchicalDataGrid ID="test" InitialDataBindDepth="1" runat="server" AutoGenerateColumns="false"
AutoGenerateBands="false" ViewStateMode="Enabled" DataKeyFields="ModuleID"
OnRowUpdating="Module_RowUpdating" Width="100%" OnItemCommand="test_ItemCommand" >
<ClientEvents Initialize="InitializHandler" Click="ClickHandler" />
<ExpandCollapseAnimation SlideOpenDirection="Auto" SlideOpenDuration="300" SlideCloseDirection="Auto"
SlideCloseDuration="300" />
<Columns>
<ig:BoundDataField DataFieldName="RolePermissionID" Key="RolePermissionID" Hidden="true" />
<ig:BoundDataField DataFieldName="ModuleID" Key="ModuleID" Width="100px" />
<ig:BoundDataField DataFieldName="ModuleName" Key="ModuleName" Header-Text="Module Name" />
<%-- <ig:TemplateDataField Key="tdfPermissionView">
<ItemTemplate>
<asp:CheckBox ID="chkModulePermissionView" runat="server" Checked='<%# Eval("PermissionView") %>' />
</ItemTemplate>
</ig:TemplateDataField>--%>
<ig:BoundCheckBoxField DataFieldName="PermissionView" Key="PermissionView" Header-Text="View" />
<ig:BoundCheckBoxField DataFieldName="PermissionAdd" Key="PermissionAdd" Header-Text="Add" />
<ig:BoundCheckBoxField DataFieldName="PermissionEdit" Key="PermissionEdit" Header-Text="Edit" />
<ig:BoundCheckBoxField DataFieldName="PermissionDelete" Key="PermissionDelete" Header-Text="Delete" />
</Columns>
<Behaviors>
<ig:EditingCore BatchUpdating="true" AutoCRUD="false">
<Behaviors>
<ig:CellEditing>
</ig:CellEditing>
</Behaviors>
</ig:EditingCore>
</Behaviors>
<Bands>
<ig:Band DataMember="Tabs" Key="Tabs" AutoGenerateColumns="false" DataKeyFields="ModuleTabID" Width="100%" OnRowUpdating="Tab_RowUpdating">
<Columns>
<ig:BoundDataField DataFieldName="ModuleTabID" Key="ModuleTabID" />
<ig:BoundDataField DataFieldName="TabName" Key="TabName" Header-Text="Tab Name" />
<%--<ig:TemplateDataField Key="CheckBox">
<Header Text="CheckBox" />
<ItemTemplate>
<asp:CheckBox ID="CheckBox1" runat="server" Checked='<%# Eval("PermissionView") %>' />
</ItemTemplate>
</Columns>
<Behaviors>
<ig:EditingCore>
<Behaviors>
<ig:CellEditing></ig:CellEditing>
</Behaviors>
</ig:EditingCore>
</Behaviors>
<Bands>
<ig:Band DataMember="Tablets" Key="Tablets" AutoGenerateColumns="false" DataKeyFields="ModuleTabTabletID, ModuleTabID" Width="100%" OnRowUpdating="Tablet_RowUpdating">
<Columns>
<ig:BoundDataField DataFieldName="ModuleTabTabletID" Key="ModuleTabTabletID" />
<ig:BoundDataField DataFieldName="TabletName" Key="TabletName" Header-Text="Tablet Name" />
</Columns>
<Behaviors>
<ig:EditingCore>
<Behaviors>
</Behaviors>
</ig:EditingCore>
</Behaviors>
</ig:Band>
</Bands>
</ig:Band>
</Bands>
</ig:WebHierarchicalDataGrid>
JS Code:
var whdg;
function InitializHandler(sender, args) {
whdg = sender;
var isChecked = false;
// Loop through all child island's rows check either uncheck the checkbox according to parent row checkbox state.
function ClickHandler(sender, args) {
isChecked = args.get_item().get_row().get_cell(3).get_element().children[0].checked;
var rowIndex = args.get_item().get_row().get_index();
var childGrids = whdg.get_rows().get_row(rowIndex).get_rowIslands();
alert(childGrids[0].get_rows().get_length());
for (var j = 0; j < childGrids[0].get_rows().get_length() ; j++) {
if (isChecked) {
.get_row(j).get_cell(3)
.get_element()
.children[0].checked = false;
C# Code:
protected void Tab_RowUpdating(object sender, RowUpdatingEventArgs e)
RolePermission rolePermission = new RolePermission();
if (e.Values["RolePermissionID"] == null)
rolePermission.RolePermissionID = 0;
else
rolePermission.RolePermissionID = e.Values["RolePermissionID"].ToString().ToInt32();
rolePermission.RoleID = hdnID.Value.ToInt32(); ;
rolePermission.ModuleTabID = e.Values["ModuleTabID"].ToString().ToInt32();
rolePermission.PermissionView = Convert.ToBoolean(e.Values["PermissionView"]);
rolePermission.PermissionAdd = Convert.ToBoolean(e.Values["PermissionAdd"]);
rolePermission.PermissionEdit = Convert.ToBoolean(e.Values["PermissionEdit"]);
rolePermission.PermissionDelete = Convert.ToBoolean(e.Values["PermissionDelete"]);
_roleManagement.SaveRolePermissionOtherTab(rolePermission);
