Has anyone done this? If so, could I get assistance with update the style of this button to match the other buttons that I am using on
the website. I am using the Macintosh WebImageButton style.
Please and thank you
Paul
Hello Pavel,
I see. Well the Asp.net FileUpload generates a simple input:
<input type="file" name="FileUpload1" id="FileUpload1">
The WebImageButton generates a much more complex Dom structure than that so I don’t think you’d be able to modify it with simple css. You might have to generate a more complex html around the file upload to get the same look.
Best Regards,
Maya Kirova
Infragistics, Inc.
Thank you. I was referring more to the ASP.NET Fileupload control, not the one from Infragistics.
The WebUpload doesn’t share the same presets as the WebImageButton. In fact it’s client side implementation is based on the igUpload widget. As such it has a different theming structure than the WebImageButton.
It uses the themes which are added by default in the <AppRoot>/ig_ui/css/themes folder when you add the WebUpload control to your page. Depending on which theme is referenced on the page the upload button will appear different.
Unfortunately we do not provide a theme that looks similar to the Macintosh preset for the igUpload, however our IgniteUI controls support jQueryUI themes as well as Bootstrap themes which you can additionally modify to achieve a similar look.
For more details on the theming you can refer to the following topics:
http://www.igniteui.com/help/deployment-guide-styling-and-theming#_Using_Theme_Roller
http://www.igniteui.com/help/deployment-guide-styling-and-theming#Using_Bootstrap_Theme_Generator
Another options is to modify the classes directly in the related infragistics.theme.css folder or overwrite them in the your page in order to change the look of the control. You can find a full list of the classes names and what they’ll affect here: http://help.infragistics.com/jQuery/2015.2/ui.igupload#theming
