Cell editing is not working after sorting when we added editor providers to columns. We are able to edit these cells when grid is not sorted, but when sorted cell is not sorting. II have attached a sample for it. Please go through it and kindly guide us.
Hi Divya Jain,
As you suggested i have installed free trial of 15.2 version and tested a sample, it is working successfully. However when we are trying to upgrade our application from V11.2 to v15.2 we are getting index error or negative index error. so we are doing it manually. Do we have to take a separate key for v15.2 even though we have key for v11.2 or any workaround to upgrade currently installed v11.2 to v15.2. Please note that we are using v15.2 trail version for now.
Hello Avinash ,
I have investigated and researched the cause of the exception and was not able to find a reasonable solution in 11.2.
It is recommended to upgrade to 15.1 or later to resolve this .
Let me know if I may be of further assistance.
Thank you Divya.
Please update us if there is any workaround to resolve this issue with 11.2 version or is upgrading is the only option.
I reproduced the error when I was trying to edit the date picker after sorting . I did some research and found that this bug has been fixed in the latest version of 15.1.Please try to update your version .
Please note that we do not support 11.2 anymore.
Refer to the following Infragistics Product Lifecycle link for more information :http://ko.infragistics.com/support/product-lifecycle
Let me know if you need more information.
Adding source code to the above post.
