160
Problem with WebDropDown date display
I have an issue with webdropdowns. I'm using WebDropDowns in a WebDatagrid via dropdownprovider. The dropdown contains a list of dates. The date format shown in the grid cell is correct, and the data format down in the list part of dropdown list is correct. But the value shown in the dropdown control itself is incorrect. The incorrect date format only shows up when I click on any cell the dropdown column. I uploaded an image of this issue, and hope it can explain better. The image is in this link: http://imgur.com/c5C4Y2E Please help me get the date format fixed.
More detail on my grid set up if it helps with the issue:
I'm using the dropdown in a BoundDataField inside a WebDataGrid. The BoundDataField has these properties set: Key="DropDown" DataFormatString="{0:ddd M/dd}" DataType="System.DateTime"
And the editor control inside the dropdownprovider has these properties set: EditorControl ID="DropDownControl" DisplayMode="DropDownList" ClientEvents-SelectionChanged="Some_Event"
The datasource for the Dropdown control is a dataset with 2 columns, one column has the type DateTime, and dropdown's ValueField is set to this column. The other column in the dataset is type string, it holds the date converted to {0:ddd M/dd} format, and the dropdown's TextField is set to this column.
Dan Ding
