I'm loading long texts from a database into a WebHTMLEditor with a fixed width. Is there a possibility to force a line wrap to prevent a horizontal scrollbar to appear?
Thank you in advance!
Thanks very much for your feedback. I reproduced the issue with your settings on IE7.
You can submit this problem to dev support at:
http://devcenter.infragistics.com/Protected/SubmitSupportIssue.aspx
that bevavior would be great - but the control behaves different. This is how to reproduce the problem with IG 2008.1:
The behavior you want is the default behavior for WebHtmlEditor when have white space, but when you don't have white spaces, WebHtmlEditor takes text like one word and adds scrollbar. Please, see the screen shot attached. What am I missing?
Hope this helps.
