60
Adding an empty value to adropdownprovider gives ASYNCRequest failure
Hi all,
I am using the following code in pageload of my usercontrol where infragistics is used.
In Page_Load()
DropDownProvider Statusddl = new DropDownProvider();
Statusddl.ID = "Statusddl_" + editcolumns.IndexOf(assignedToColumnSetting).ToString();
Statusddl.EditorControl.Items.Add(new Infragistics.Web.UI.ListControls.DropDownItem(""));
this.UltraWebGrid.EditorProviders.Add(Statusddl);
switch (assignedToColumnSetting.ColumnKey)
case "Logic Status":
foreach (string dv in BLDomain.GetDomainValueListByDomainName("Logic Status", this.CurrentLibraryId))
Statusddl.EditorControl.Items.Add(new Infragistics.Web.UI.ListControls.DropDownItem(dv));
break;
case "Logic1 Status":
foreach (string dv in BLDomain.GetDomainValueListByDomainName("Logic1 Check Status", this.CurrentLibraryId))
break;
case "Logic2 Status":
foreach (string dv in BLDomain.GetDomainValueListByDomainName("Logic2 Check Status", this.CurrentLibraryId))
break;
case "PhySym Status":
foreach (string dv in BLDomain.GetDomainValueListByDomainName("Physical Status", this.CurrentLibraryId))
break;
case "iPN Status":
foreach (string dv in BLDomain.GetDomainValueListByDomainName("IPN Status", this.CurrentLibraryId))
break;
default:
Statusddl = ddl;
break;
assignedToColumnSetting.EditorID = Statusddl.ID;
Now in UI of my user control the definition of webdatagrid is as follows
EnableRelativeLayout="false" HeaderCaptionCssClass="GridHeaderCaption"
OnInit="UltraWebGrid_Init" onrowupdated="UltraWebGrid_RowUpdated" OnRowUpdating="UltraWebGrid_RowUpdating" OnColumnMoved="UltraWebGrid_ColumnMoved"
EnableAjax="true" EnableAjaxViewState="true" EnableDataViewState="True" OnColumnResized="UltraWebGrid_ColumnResized" OnColumnSorted="UltraWebGrid_ColumnSorted">
<ig:Sorting >
The RowUpdating method
protected void UltraWebGrid_RowUpdating(object sender, RowUpdatingEventArgs e)
string requestId = e.Values[MyQueueConst.REQUEST_ID].ToString();
//Get the Column name being Edited
string colname = string.Empty;
string assignedTo = string.Empty;
foreach (DictionaryEntry entry in e.OldValues)
if (e.Values.ContainsKey(entry.Key) && e.Values[entry.Key].Equals(entry.Value))
continue;
else
colname = entry.Key.ToString();
assignedTo = e.Values[colname].ToString();
int iRequestId = Int32.Parse(requestId);
BLRequest.UpdateRequestAssignmentForASPNET(iRequestId, colname, assignedTo, this.CurrentLibraryId, this.CurrentUser);
//Update the datasoure
DataRow currentRow = this.HomeGridDataSource.Select(MyQueueConst.REQUEST_ID + "=" + requestId).FirstOrDefault();
currentRow[colname] = assignedTo;
this.UltraWebGrid.DataSource = this.HomeGridDataSource;
this.UltraWebGrid.DataBind();
Now, when I try to edit the dropdown from the Infragistics Grid UI I get the following Error, especially since I am adding the Empty entry in my dropdown provider
Async request failed
[ArgumentOutOfRangeException]: Insertion index was out of range. Must be non-negative and less than or equal to size.
Parameter name: index
at System.Collections.ArrayList.Insert(Int32 index, Object value)
at Infragistics.Web.UI.Framework.ObjectCollection.InternalInsert(Int32 index, ICollectionObject collectionObject)
at Infragistics.Web.UI.Framework.ViewStateJournal.LoadJournalState(ObjectCollection objectCollection, String actions)
at Infragistics.Web.UI.Framework.ObjectCollection.LoadViewState(Object savedState)
at Infragistics.Web.UI.Framework.ObjectCollection.System.Web.UI.IStateManager.LoadViewState(Object savedState)
at Infragistics.Web.UI.ListControls.ListControl.LoadViewState(Object savedState)
at System.Web.UI.Control.LoadViewStateRecursive(Object savedState)
at System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState)
at System.Web.UI.Page.LoadAllState()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
[HttpUnhandledException]: Exception of type 'System.Web.HttpUnhandledException' was thrown.
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.default_aspx.ProcessRequest(HttpContext context) in c:\Users\pavankka\AppData\Local\Temp\Temporary ASP.NET Files\root\b51783cb\a3e13343\App_Web_0gcorezp.1.cs:line 0
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
A Screenshot is here
Any Idea of why is this happening? I am using Infragistics version 12.2
  • 25665
    Hello Prabha,
    It seems like from the code this is something you setup for multiple columns. Do they all throw the error? Do you have a sample you can provide me that demonstrates the issue so I can dug further into the code and see how it is running?
