20
Could not load file or assembly error
I copied a DNN site from a working production server to a virtual dev server.  The dev server does not have any version of infragistics installed.  It may have temporarily had a NetAdvantage trial installed but doesn't anymore.  When I try to browse to the site I receive the error below.  Its a DNN site without any infragistics controls. There are no references to the assemblies in my web.config, global or machine.config.  Where is it trying to load the infragistic assemblies from?  I have deleted the framework 2.0 temp folders and issued the IISRESET command and even rebooted the virtual server.
BTW I also get the error from the empty default website too.
eFlyerMan
N3113R
Could not load file or assembly 'Infragistics2.WebUI.UltraWebNavigator.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'Infragistics2.WebUI.UltraWebNavigator.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'Infragistics2.WebUI.UltraWebNavigator.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileNotFoundException: Could not load file or assembly 'Infragistics2.WebUI.UltraWebNavigator.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.]
System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +0
System.Reflection.Assembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection) +54
System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +211
System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection) +141
System.Reflection.Assembly.Load(String assemblyString) +25
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +32
[ConfigurationErrorsException: Could not load file or assembly 'Infragistics2.WebUI.UltraWebNavigator.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.]
System.Web.Configuration.CompilationSection.LoadAssemblyHelper(String assemblyName, Boolean starDirective) +596
System.Web.Configuration.CompilationSection.LoadAssembly(AssemblyInfo ai) +70
System.Web.Compilation.BuildManager.GetReferencedAssemblies(CompilationSection compConfig) +177
System.Web.Compilation.BuildProvidersCompiler..ctor(VirtualPath configPath, Boolean supportLocalization, String outputAssemblyName) +185
System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed) +350
System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories) +125
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +378
[HttpException (0x80004005): Could not load file or assembly 'Infragistics2.WebUI.UltraWebNavigator.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified.]
System.Web.Compilation.BuildManager.ReportTopLevelCompilationException() +57
System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled() +612
System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters) +644
System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +3465427
System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +69
System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +279
Version Information: Microsoft .NET Framework Version:2.0.50727.1433; ASP.NET Version:2.0.50727.1433
  • 191
    We've had exactly the same problem, although the version of Infragistics was different. Here is an excerpt from the email I received today from our client:
    "I have good news. I was able to sit down with NSU and we purged the ASP.NET temp files and found an orphan config file that was sitting two directories up. Not sure how IIS picked it up but it did. So, we got the server back to normal. I have re-run the latest installer and so far everything seems ok. I plan to continue to monitor the site over the weekend. If everything seems ok by Monday I will set up moving it to production."
    Hope, this helps.
    Alex, RJN GROUP.
