I have a WebHierarchicalDataSource set up and the parent and child datasources use stored procedures. Within the Smart Tag screens I am able to tie the two together with the "Claim_ID" field and my stored procedure for the child datasource includes a "Claim_ID" parameter, but I can't figure out how to setup the select parameter in the child datasource. As of now it looks like this: . How do I make it send the "Claim_ID" that is selected in the parent datasource?
Thanks! This was helpful. I had set the DataRelation field, but it hadn't dawned on me that I didn't need the "select parameter". Once I removed that piece, it worked fine.
You can look into this sample for an example on how to bind to a grid using a WebHierarchicalDataSource:
http://ko.infragistics.com/samples/aspnet/hierarchical-data-grid/binding-to-different-types
In the DataRelation field, the ID and view of the child are stated which establishes the relation between the parent and child bands.
Let me know if you have any further questions.
