I have a datatable bound to a Gantt chart. Is it possible to display another field (other that <DATA_VALUE> or <ITEM_LABEL>) in the tooltip?
Doing a quick search for "tooltip" in the WebChart forums yielded this nice post:
http://forums.infragistics.com/forums/p/5216/23656.aspx#23656
Which has lots of helpful links and information.
If you do a quick search for tooltip in the WebChart forum you'll get some good results, here is one:
Here are the links that provide some great information:
Predefined Labels:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.1/CLR2.0/html/Chart_Use_Predefined_and_Custom_Label_Styles.html
Making Custom Labels:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.1/CLR2.0/html/Chart_Customize_Labels_Using_the_IRenderLabel_Interface.html
Knowledge Base Article about Making Custom Labels:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=2807
More info about Predefined Labels:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.1/CLR2.0/html/Chart_Label_Formatting.html
Hope this info helps you solve your problem, and let me know how it goes.
-Paul
