Hi
When we add a new child row (band) in the web hierarchical data grid - there appears to be animation which we would like to turn off.
Not sure how to turn off this from happening - I have attached a short video to show you what it is doing:
1. Row fading from blue to clear (takes too long)
2. Other CSS (grey cells) then experience a delay in rendering.
Do we have any options to be able to stop this so the row just appears without any effects?
Thanks... M
Hello Marcus,
It looks like this is custom animation implementation. We can only provide support for the default styles and animations.
If you believe that the issue is caused by the Infragistics product, please specify why and provide a working sample demonstrating the issue.
Best Regards,Aleksandar KamenovEntry-level Software DeveloperInfragistics, Inc.
Hello Aleksander,
We have pinpointed it down to the 'Enable Batch Updating for Child Band' setting.
We need this turned on and as soon as you have turned on the blue pulse appears - the infragistics sample shows this - see attached image:
http://ko.infragistics.com/samples/aspnet/hierarchical-data-grid/batch-updating
This is just a style into the ig_dataGrid.css on 523 row. The style can be removed or replaced with another.
Please let me know if you have further questions.
