I need to have a multi-column header with two CheckBox. If I write this code:
<ig:GroupField Key="clmDayMonday"> <Header Text="<%$ Resources:Language, lbl_DayMon %>" /> <Columns> <ig:BoundCheckBoxField Width="14%" DataFieldName="MonMorShift" DataType="System.Boolean" Key="clmMonMorShift" CssClass="textAlignCenter"> <CheckBox CheckedImageUrl="../../Images/bg_check.png" UncheckedImageUrl="../../Images/bg_uncheck.png" PartialImageUrl="../../Images/bg_uncheck.png" /> <Header Text="<%$ Resources:Language, clm_MorShift %>" /> </ig:BoundCheckBoxField> <ig:BoundCheckBoxField Width="14%" DataFieldName="MonAftShift" DataType="System.Boolean" Key="clmMonAftShift" CssClass="textAlignCenter"> <CheckBox CheckedImageUrl="../../Images/bg_check.png" UncheckedImageUrl="../../Images/bg_uncheck.png" PartialImageUrl="../../Images/bg_uncheck.png" /> <Header Text="<%$ Resources:Language, clm_AftShift %>" /> </ig:BoundCheckBoxField> </Columns> </ig:GroupField>
it doesn't work.
I receive the error message below:
System.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Web.UI.Framework.AppStyling.StyleBot.ImageDirectoryResolved() at Infragistics.Web.UI.Framework.AppStyling.StyleBot.ResolveImageUrl(String imageUrl, Boolean useCache) at Infragistics.Web.UI.Framework.ImageObject.ResolveImageUrl(String url, String defaultUrl) at Infragistics.Web.UI.Framework.GridCheckBox.GetRenderImageUrl(CheckBoxState state) at Infragistics.Web.UI.GridControls.BoundCheckBoxField.CalculateImageUrl(CheckBoxState state) at Infragistics.Web.UI.GridControls.GridRecordItem.GenerateAttributes(Hashtable attributes) at Infragistics.Web.UI.GridControls.XPathDataNavigable.GenerateAttributes() at Infragistics.Web.UI.GridControls.XPathDataNavigable.get_XPathAttributes() at Infragistics.Web.UI.GridControls.XPathDataNavigable.get_HasAttributes() at Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) at Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) at Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) at Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) at Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) at Infragistics.Web.UI.GridControls.XPathDataNavigator.OutputToStream(XPathDataNavigator xpdn, XmlTextWriter stream, HtmlTextWriter htmlWriter) at Infragistics.Web.UI.GridControls.XPathDataNavigator.get_OuterXml() at Infragistics.Web.UI.GridControls.GridRenderer.RenderContents(HtmlTextWriter writer) at Infragistics.Web.UI.Framework.RunBot.HandleRenderContents(HtmlTextWriter writer, RendererBase renderer) at Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.RenderContents(HtmlTextWriter writer) at Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Page.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Could you tell me what's the problem?
Waiting for your answer,Best regards.
With the last version this isn't reproduce. My recommendation is to update to the last version and you will not have a problem with this issue anymore.
Here you can see product lifecycle: http://ko.infragistics.com/support/product-lifecycle.
If you have further questions, please feel free to contact us.
Hello Aleksandar, I send you a sample to reproduce the error.
Best Regards,
Thank you for post in forum.
I couldn't reproduce the issue. Could you please send me an isolated working sample to reproduce the error.
I'm looking forward your reply.
