The UltraWebGrid inside WebDropDown not displayed and not sure why :) I'm sure someone know what's wrong with my code below.
<ig:WebDropDown ID="wcmb_tollingevents2" runat="server" BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px" ComboTypeAhead="Suggest" ForeColor="Black" OnInitializeLayout="wcmb_tollingevents_InitializeLayout2" SelBackColor="DarkBlue" SelForeColor="White" Width="500"> <Items> <ig:DropDownItem> </ig:DropDownItem> </Items> <ItemTemplate> <igtbl:UltraWebGrid ID="wcmb_tollingevents_grid" runat="server" AutoGenerateColumns="False" Height="100px" Width="400px"> <Bands> <igtbl:UltraGridBand> <Columns> <igtbl:UltraGridColumn AllowUpdate="Yes" Type="CheckBox" Width="5%"> <Header Caption="#"> </Header> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="DisplayStatusEventDate" Width="15%"> <Header Caption="Event Date"> <RowLayoutColumnInfo OriginX="1" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="1" /> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Description" Width="80%"> <Header Caption="Status Event"> <RowLayoutColumnInfo OriginX="2" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="2" /> </Footer> </igtbl:UltraGridColumn> </Columns> </igtbl:UltraGridBand> </Bands> </igtbl:UltraWebGrid> </ItemTemplate> </ig:WebDropDown>
Hello Benjamin,
Unfortunately, UltraWebGrid is no longer supported by Infragistics Developer Support, and is no longer eligible for active maintenance or bug fixes. For information on the lifecycle of Infragistics products, please refer to the Product Lifecycle page via the following link:
https://ko.infragistics.com/support/product-lifecycle
The decision to change the classic controls architecture and continue with the Aikido (modern ones) was influenced by the browsers environment evolution. What is more, this decision was also in order to best fit our controls in the constantly changing environment and to provide more functionality and stability.
You can refer to the installed product documentation and our online Knowledge Base for answers to the how-to questions that you may have. You can reach our Knowledge Base at the following link:
http://devcenter.infragistics.com/Support/KnowledgeBase.Aspx
You may be able to get assistance from other customers who have encountered similar issues in the past, using the peer-to-peer forums on our website. Please note that Infragistics Developer Support does not monitor these forums, and that answers provided are most likely coming from other users of the product. You can reach our peer-to-peer forums using the following link:
https://ko.infragistics.com/community/forums
Aneta Gicheva,
Thanks Aneta. The problem is the application can't be upgraded right now and still has to target .NET Framework 3.5.
I didn't see WebDataGrid in Infragistics35.xx version.
Hello Binyam,
Thank you for using our community!
I’ve investigated the code sample you provided. I noticed that you are using UltraWebGrid. This control has been retired. Please, keep in mind that the Aikido controls are built on a completely different framework and their behaviors and properties will be different compared to their Classical Controls counterparts. As a starting point when migrating from the old UltraWebGrid to the new WebDataGrid/WebHierarchicalDataGrid you can refer to this article:
https://ko.infragistics.com/community/blogs/b/craig_shoemaker/posts/introducing-the-webdatagrid-webhierarchicaldatagrid-cheat-sheet
There you’ll find the so called WebDataGrid / WebHierarchicalDataGrid Cheat Sheet which outlines most of the functionalities of the new grids.
You could take advantage of our API documentation. The following link gives more information about the templating.
https://ko.infragistics.com/help/aspnet/webdropdown-templating
Furthermore, I’ve created a runnable code sample. Please test it on your side and let me know how it works for you.
