Hi Team,
I found in Infragistics grid Cell size mismatch when resizing columns . It happen when I increase the header at some width after 250px.It happens only in chrome and edge browser. In IE its working fine.
Can you please help me for this issue.
I am using Asp.net Infragistics version 11.1
Thank you for contacting Infragistics Developer Support!
Please note that the version you are using is retired several years ago and understandably would not work with modern browsers that were released after the last volume of the classic controls, which was Infragistics NetAdvantage v11.1 of ASP.NET. The product lifecycle is stated in the following page:http://ko.infragistics.com/help/product-lifecycle.The only possible solution in this case is to use a product that is supported under newer browsers, which you can identify in the supported environments page at:http://ko.infragistics.com/support/supported-environments.So what you could do is to upgrade to the new ASP.NET Ajax tool-set. You can take a look at it at:http://ko.infragistics.com/products/aspnet.
