20
Dynamically column add problem
 Hi all
I'm been looking around for an answer to this but looks like i can't find any
I'm using Infragistics 17.1 WebDataGrid i added dynamically checkbox column and paging  function
as you can see in the attached code
The problem is that when click the Paging button after changing the checkbox value, the following error occurs:
Thanks in advance for any help.
code
BoundCheckBoxField CKfield = new BoundCheckBoxField();
CKfield.Key = ColumnName;
CKfield.Header.Text = HeaderCaption;
CKfield.DataFieldName = ColumnName;
CKfield.Width = Width;
#region Column HeaderAlign
if (HeaderAlign == HorizontalAlign.Center)
CKfield.Header.CssClass = "HCAlign";
if (HeaderAlign == HorizontalAlign.Justify)
CKfield.Header.CssClass = "HJAlign";
if (HeaderAlign == HorizontalAlign.Left)
CKfield.Header.CssClass = "HLAlign";
if (HeaderAlign == HorizontalAlign.NotSet)
if (HeaderAlign == HorizontalAlign.Right)
CKfield.Header.CssClass = "HRAlign";
#endregion
#region Column ContentAlign
if (ColumnAlign == HorizontalAlign.Center)
CKfield.CssClass = "CAlign";
if (ColumnAlign == HorizontalAlign.Justify)
CKfield.CssClass = "JAlign";
if (ColumnAlign == HorizontalAlign.Left)
CKfield.CssClass = "LAlign";
if (ColumnAlign == HorizontalAlign.NotSet)
if (ColumnAlign == HorizontalAlign.Right)
CKfield.CssClass = "rAlign";
#endregion
if (Hidden)
CKfield.Hidden = true;
else
CKfield.Hidden = false;
EditingColumnSetting set = new EditingColumnSetting();
set.ColumnKey = ColumnName;
if (CheckUpdate == AllowUpdate.Yes)
set.ReadOnly = false;
else
set.ReadOnly = true;
base.Behaviors.CreateBehavior<EditingCore>();
base.Behaviors.EditingCore.Behaviors.CreateBehavior<CellEditing>();
base.Behaviors.EditingCore.Behaviors.CellEditing.ColumnSettings.Add(set);
base.Columns.Add(CKfield);
error :
[NotSupportedException]: A row can only be updated or deleted if the DataKeyFields property is set.
위치: Infragistics.Web.UI.GridControls.EditingCore.OnAction(String actionType, Object id, Object value, Object tag)
위치: Infragistics.Web.UI.GridControls.GridBehavior.Infragistics.Web.UI.GridControls.IGridBehavior.OnAction(String actionType, Object id, Object value, Object tag)
위치: Infragistics.Web.UI.GridControls.GridBot.LoadAdditionalClientState(Object state)
위치: Infragistics.Web.UI.Framework.RunBot.HandleRaisePostDataChangedEvent()
위치: Infragistics.Web.UI.GridControls.GridBot.HandleRaisePostDataChangedEvent()
위치: Infragistics.Web.UI.Framework.Data.FlatDataBoundControl.RaisePostDataChangedEvent()
위치: System.Web.UI.Page.RaiseChangedEvents()
위치: System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
[HttpUnhandledException]: &#39;System.Web.HttpUnhandledException&#39; 형식의 예외가 Throw되었습니다.
위치: System.Web.UI.Page.HandleError(Exception e)
위치: System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
위치: System.Web.UI.Page.ProcessRequest()
위치: System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context)
위치: System.Web.UI.Page.ProcessRequest(HttpContext context)
위치: ASP.default2_aspx.ProcessRequest(HttpContext context) 파일 c:\Users\YoonPC\AppData\Local\Temp\Temporary ASP.NET Files\vs\0872ed3f\1efd606c\App_Web_edxwoipc.0.cs:줄 0
위치: System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
위치: System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
