Hi
I'am working with infragistics webdatagrid (Version: 15.1.20151.1018). This component is used in a master page.
I create dynamicaly the grid (the grid is put in a webTab) in witch a put a image button. So when the end user is clicked in the button a should open a new page but the event doesn't fired.
Is there a work a round for this problem?
Thank's
Christophe
//Create the gridView when fill the Tab
private void FillTab(Infragistics.Web.UI.LayoutControls.ContentTabItem tab, int index)
//Select the data via Linq
var ResuStdOper = (from s in db.vRESU_STD_OPERs
where s.NOM_LIGNE.Equals("AC02")
select s).ToList();
WebDataGrid GV = new WebDataGrid();
GV.ID = "GV" + index.ToString();
GV.AutoGenerateColumns = false;
GV.DataKeyFields = "ID_RESULTAT";
GV.EnableAjax = false;
GV.EnableDataViewState = true;
GV.EnableViewState = true;
GV.ItemCommand += new ItemCommandEventHandler(WebDataGrid1_ItemCommand);
Selection gridSelection = GV.Behaviors.CreateBehavior<Selection>();
gridSelection.CellClickAction = CellClickAction.Row;
gridSelection.RowSelectType = SelectType.Single;
RowSelectors gridselectorw = GV.Behaviors.CreateBehavior<RowSelectors>();
gridselectorw.Enabled = true;
Selection selectionBehavior = GV.Behaviors.Selection;
if (selectionBehavior == null)
// Create the behavior
Selection selection = new Selection();
// Add to behaviors collection
GV.Behaviors.Add(selection);
// Set its options
selection.CellClickAction = CellClickAction.Row;
selection.RowSelectType = SelectType.Single;
RowSelectors gridselectorbehavior = GV.Behaviors.RowSelectors;
if (gridselectorbehavior==null)
//Add the
TemplateDataField templateField1 = new TemplateDataField(true);
templateField1.Key = "TemplateField1";
templateField1.Header.Text = "Template Column";
GV.Columns.Add(templateField1);
TemplateDataField templateColumn1 = (TemplateDataField)GV.Columns["TemplateField1"];
templateColumn1.ItemTemplate = new CustomItemTemplate();
var col1 = new BoundDataField { Key = "NOM_STANDARD" };
col1.Header.Text = "Nom standard";
col1.Width = 100;
var col2 = new BoundDataField { Key = "NOM_OPERATEUR" };
col2.Header.Text = "Nom opérateur";
col2.Width = 75;
GV.Columns.Add(col1);
GV.Columns.Add(col2);
GV.DataSource = ResuStdOper;
GV.DataBind();
tab.Controls.Add(GV); //Add the grid to the tab
GV.EnsureTemplates();
//???? Why is this event not fired????
protected void WebDataGrid1_ItemCommand(object sender, HandleCommandEventArgs e)
string IdResu = e.CommandArgument.ToString();
//The class used for create the button
public class CustomItemTemplate : ITemplate
#region ITemplate Members
public void InstantiateIn(Control container)
ImageButton imgBtn = new ImageButton();
imgBtn.ID = "ImageButton1";
imgBtn.ImageUrl = "images/edit.png";
imgBtn.Width=System.Web.UI.WebControls.Unit.Pixel(32);
imgBtn.Height = System.Web.UI.WebControls.Unit.Pixel(32);
imgBtn.CommandName = "security";
imgBtn.CommandArgument = DataBinder.Eval((((Infragistics.Web.UI.TemplateContainer)container).DataItem), "ID_RESULTAT").ToString();
imgBtn.ToolTip = "Manage Security";
container.Controls.Add(imgBtn);
#endregion
App_Data.ADHERENCE_CILDataContext db = new App_Data.ADHERENCE_CILDataContext(); var ResuStdOper = (from s in db.vRESU_STD_OPERs where s.NOM_LIGNE.Equals("AC02") select s).ToList(); //GV.AutoGenerateColumns = false; //GV.RowStyle.BackColor = Color.Blue; //GV.RowStyle.BorderColor = Color.Black; //GV.RowStyle.BorderWidth = 1; //GV.DataKeyNames = "id_resultat"; //BoundField bf = new BoundField(); //bf.HeaderText = "Nom standard"; //bf.DataField = "NOM_STANDARD"; //GV.Columns.Add(bf); //BoundField bf1 = new BoundField(); //bf1.HeaderText = "Nom opérateur"; //bf1.DataField = "NOM_OPERATEUR"; //GV.Columns.Add(bf1); WebDataGrid GV = new WebDataGrid(); GV.ID = "GV" + index.ToString(); GV.AutoGenerateColumns = false; GV.DataKeyFields = "ID_RESULTAT"; GV.EnableAjax = false; GV.EnableDataViewState = true; GV.EnableViewState = true; GV.ItemCommand += new ItemCommandEventHandler(WebDataGrid1_ItemCommand); https://ko.infragistics.com/community/forums/t/93050.aspx Selection gridSelection = GV.Behaviors.CreateBehavior<Selection>(); gridSelection.CellClickAction = CellClickAction.Row; gridSelection.RowSelectType = SelectType.Single; RowSelectors gridselectorw = GV.Behaviors.CreateBehavior<RowSelectors>(); gridselectorw.Enabled = true; // To get reference to a behavior, use its property of the same name //http://help.infragistics.com/Help/Doc/ASPNET/2011.2/CLR4.0/html/WebDataGrid_Adding_a_Behavior_at_Runtime.html Selection selectionBehavior = GV.Behaviors.Selection; if (selectionBehavior == null) { // Create the behavior Selection selection = new Selection(); // Add to behaviors collection GV.Behaviors.Add(selection); // Set its options selection.CellClickAction = CellClickAction.Row; selection.RowSelectType = SelectType.Single; } RowSelectors gridselectorbehavior = GV.Behaviors.RowSelectors; if (gridselectorbehavior==null) { } //ImageButton imgBtn = new ImageButton(); //imgBtn.ID = "ImageButton1"; //imgBtn.ImageUrl = "images/edit.png"; //imgBtn.CommandName = "security"; //imgBtn.CommandArgument = ((DataRowView)((TemplateContainer)container).DataItem)["ID_CATEGORIE"].ToString(); //imgBtn.ToolTip = "Manage Security"; //container.Controls.Add(imgBtn); TemplateDataField templateField1 = new TemplateDataField(true); templateField1.Key = "TemplateField1"; templateField1.Header.Text = "Template Column"; GV.Columns.Add(templateField1); TemplateDataField templateColumn1 = (TemplateDataField)GV.Columns["TemplateField1"]; templateColumn1.ItemTemplate = new CustomItemTemplate(); var col1 = new BoundDataField { Key = "NOM_STANDARD" }; col1.Header.Text = "Nom standard"; col1.Width = 100; var col2 = new BoundDataField { Key = "NOM_OPERATEUR" }; col2.Header.Text = "Nom opérateur"; col2.Width = 75; GV.Columns.Add(col1); GV.Columns.Add(col2); GV.DataSource = ResuStdOper; GV.DataBind(); tab.Controls.Add(GV); GV.EnsureTemplates();
Hello Strich,
I followed the code you have provided and was unable to reproduce the behavior you're describing.
I have created a sample of WebdataGrid. In the sample I added a master page and added a WebDatagrid in a webTab control.I added an ImageButton as a template data field in the grid And now when I clicked the image button, WebDataGrid1_ItemCommand event does fired.
I have attached the sample project I used to test this. Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
Please note as the provided code has lots of dependent code I was not able to include it into my sample. I would recommend you to isolate the code and debug it to find the cause of the issue.
It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing. This can be done by either making the sample that I provided more like your application or by isolating the behavior from your application by removing dependencies on any third parties or databases.
Please let me know if I can provide any further assistance.
Thank you for posting to our forum.
I would like to update you that currently I am putting together all the code you have provided, in order to have a working sample and able to reproduce the same scenario at my end.
I will provide you an update by tomorrow EOD .
