// function dropTree() {
$.ajax({ type: "POST", contentType: "application/json; charset=utf-8", url: "IgTree.aspx/GetTree", data: {}, success: function (data) { if (data.d != null && data.d[0] != null) { if (data.d[0] != null) { PopulateGridWoSorting("Tree", data.d); debugger; };
}; }, error: function (data) { alert("failed posted data"); }
function PopulateGridWoSorting(iid, data) { debugger; $('#' + iid).igTreeGrid({ dataSource: data[1], primaryKey: "id", foreignKey: "ParentId", //responseDataKey: "results", dataSourceType: "json", autoGenerateColumns: false,
columns: data[0],
i am getting data from database through datatable
i works when i simply bind grid but
when i uncomment primary and foreign key data get hide except header and no error occur ....
Hello taha,
Please share your data that is returned from the server, so that I can see it and decide if your treegrid configuration is correct and what should be changed in order to work properly.
Tsanna
