Im experiencing some display issues with firefox below is a screenshot of firefox rendering:
If you notice the WebMenu when used with WebSpliter and is right next to the Splitter itself menu somehow goes under the Splitter and looks wrong as you can only see a portion of the menu, almost as if its loosing its Z order priority.
It works fine in IE.
Also for some reason is showing horizontal scroll bar even though the tree is set at 100% Verticle Height and should really show the horizontal scroll on bottom, just on top of bottomsplitter.
Again this also works fine in IE.
This is what it looks like in IE, which is correct:
I believe the best way to proceed in this types of situations is to contact Developer Support directly. They can be reached at:
http://ko.infragistics.com/gethelp/default.aspx
This way, you will either get a workaround/solution/hotfix, or this will be logged as a bug in our bug track system and assigned a number and you will be able to monitor any status change for this bug from this point on.
