DataMenuItem3.zip
I am having and issue with the DataMenuItem.ImageToolTip not working in IE11 as shown in the attached pictures. It works correctly for the DataTreeNode. I am using Infragistics45.Web.v15.1 for this.
Is that a know bug, and is there a work around that, or am I doing something wrong here?
Thanks for any help.
Hello John,
We have fixed this bug for versions 17.1 and 17.2. The fix will be available in the following service releases.
This issue doesn't have a workaround and if you need the fix I would suggest upgrading to a newer version.
Bobby Kulov
Infragistics Developer Support
