195
Solution on Customize Labels on Ultrachart
Thought this might be of help to those of you who are want to customize your Y-Axis labeling on your charts. (note: this solution is based off of the article knowledgebase regarding customize labeling that Infragistics has on their site--gotta give credit where credit is due--I just expanded and tailored it my needs) Just to illustrate:
Y-Axis DATA VALUES Label Before:
$1,000,000
$100,000
$10,000
$1,000
Y-Axis DATA VALUES Label After:
$1M
$100K
$10K
$1K
Now that takes up less space and is much more readable. Now--onto the code!
Public Class MyLabelRenderer
Implements IRenderLabel
Public Overloads Function ToString(ByVal context As Hashtable) _
As String Implements IRenderLabel.ToStringSelect Case CDbl(context("DATA_VALUE"))
Case Is < -999
Return CStr(context("DATA_VALUE")).Substring(0, 4) & "K"
Case Is < -10000
Return CStr(context("DATA_VALUE")).Substring(0, 3) & "K"
Case Is < -100000
Return CStr(context("DATA_VALUE")).Substring(0, 2) & "K"
Case Is < -1000000
Return CStr(context("DATA_VALUE")).Substring(0, 1) & "K"
Case Is < 1000
Case Is < 10000
Case Is < 100000
Case Is < 1000000
Case Is < 10000000
Return CStr(context("DATA_VALUE")).Substring(0, 1) & "M"
Case Is < 100000000
Return CStr(context("DATA_VALUE")).Substring(0, 2) & "M"
End Select
End Function
End Class
Private Sub Customize_Labels_Using_the_IRenderLabel_Interface_Load( _
ByVal sender As System.Object, _
ByVal e As System.EventArgs) Handles MyBase.Load
Me.YourChartNameHere.Axis.Y.Labels.ItemFormatString = "<MY_VALUE>"
Dim MyLabelHashTable As New Hashtable()MyLabelHashTable.Add("MY_VALUE", New MyLabelRenderer())
YourChartNameHere.LabelHash = MyLabelHashTable
End Sub
Now, I only chose to customize the Y axis because that usually contains the data values (which is what I'm interested in). You easily modify the code above to include changes in the X axis as well.
 Happy coding!
