80
WebDialogWindow and asp:UpdatePanel
I tried to use a WebDialogWindow inside a WARP and itdid not work.
Looking in this forum, I saw that the WebDialogWindow is not compatible with the WARP and Infragistics suggests using the AJAX UpdatePanel instead.
So, I swapped my WARP panel for an UpdatePanel and I get error messages on every element inside thh update panel, such as
C:\projects\PressProductionManager\SiteClient\Default.aspx(714): Build (web): Type 'System.Web.UI.UpdatePanel' does not have a public property named 'WebDialogWindow'.
C:\projects\PressProductionManager\SiteClient\Default.aspx(716): Build (web): Type 'System.Web.UI.UpdatePanel' does not have a public property named 'ContentPane'.
C:\projects\PressProductionManager\SiteClient\Default.aspx(717): Build (web): Type 'System.Web.UI.UpdatePanel' does not have a public property named 'Template'.
C:\projects\PressProductionManager\SiteClient\Default.aspx(718): Build (web): Type 'System.Web.UI.UpdatePanel' does not have a public property named 'table'.
C:\projects\PressProductionManager\SiteClient\Default.aspx(719): Build (web): Type 'System.Web.UI.UpdatePanel' does not have a public property named 'tbody'.
etc.
What am I missing?
  • 28464
    asp:UpdatePanel works a little bit differently from WARP - it requires ContentTemplate first, and the actual content can be embedded there. Example
    <asp:UpdatePanel runat="server" ID="UpdatePanel1">
         <ContentTemplate>
               <ig:WebDialogWindow .... />
        </ContentTemplate>
    </asp:UpdatePanel>
    Please, let me know if this helps.
