Hello
I tried the following experiment and my VS2008 hanged. I placed two SQL Data Sources on my page and then placed a WHDS. The WHDS has two hierarchical views, each view corresponds to one of the SQL Data Sources. Then I placed a WebGrid with the ViewType equal to Hierarchical. When I tried to data bind the webgrid to the WHDS (at design time), my VS2008 hanged. What could be wrong?
Thanks a lot.
Thanks for your reply.
Although it is an AJAX enabled project and there is an ScriptManager, I have not placed an UpdatePanel on the page.
By any chance is the WHDS inside an UpdatePanel? I experienced similar behavior, and it was determined to be because the WHDS was inside an ASP UpdatePanel. Once I moved the WHDS outside of the UpdatePanel, it worked fine.
This was confirmed to be a bug that will be fixed in the next Hotfix.
