I am using 7.2 Version, I am facing an issue that I am unable to hide the show Link Button which is showing for the Combo and Calendar controls. I am able to find the this property for Text Editor as (ShowLnkButton = "Never") but I am unable to find this for Ultra Combo and Ultra Calendar Combo. Here I am giving some screen shots also red highlighted are should be removed. Please check.
Can you please help me as soon as possible.
Are you using Windows Forms or ASP.NET? I ask because the controls listed sound more like Windows Forms control names though the forum that you posted in is for ASP.NET.
As far as the button that is highlighted, it appears as though it is likely from the Ink Provider Component. This was added in 2004 Volume 3 and the functionality comes from the Infragistics.Win.UltraWinInkProvider assembly so if you remove that assembly from your application you would likely remove those buttons.
The classic controls are retired and no longer supported. They are also not included in NetAdvantage versions 11.2 and above. I would suggest you to migrate to the new controls based on our Aikido framework. Here you can find more information on the matter:
https://ko.infragistics.com/help/aspnet/classic-control-migration-guide
http://ko.infragistics.com/community/blogs/taz_abdeali/archive/2010/03/04/asp-net-product-changes.aspx
