Hello
I have a problem to validate Infragistics.Web.UI.EditorControls for some fields, i am using the code as below:
<asp:Panel ID="dynamicFields" runat="server" Visible="False"><br /> <asp:Label ID="label_valoreTemperatura" runat="server" CssClass="genericLabel" Text="Temperatura Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_pMax" runat="server" CssClass="genericLabel" Text="Pressione Sistolica Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_pMin" runat="server" CssClass="genericLabel" Text="Pressione Diastolica Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrequenzaCardiaca" runat="server" CssClass="genericLabel" Text="Frequenza Cardiaca Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrequenzaRespiratoria" runat="server" CssClass="genericLabel" Text="Frequenza Respiratoria Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreGlicemia" runat="server" CssClass="genericLabel" Text="Glicemia Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreSPO2" runat="server" CssClass="genericLabel" Text="SpO2 Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valorePeso" runat="server" CssClass="genericLabel" Text="Peso Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDiuresi" runat="server" CssClass="genericLabel" Text="Diuresi Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreAlvo" runat="server" CssClass="genericLabel" Text="Alvo Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDieta" runat="server" CssClass="genericLabel" Text="Dieta Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreEmesi" runat="server" CssClass="genericLabel" Text="Emesi Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDrenaggio" runat="server" CssClass="genericLabel" Text="Drenaggio Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreCreatinina" runat="server" CssClass="genericLabel" Text="Creatinina Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrazioneEiezione" runat="server" CssClass="genericLabel" Text="Frazione Eiezione Rilevato: " EnableViewState="False" /><br /><br /> <ig:WebNumericEditor ID="valoreTemperatura" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="pMax" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="pMin" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrequenzaCardiaca" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrequenzaRespiratoria" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreGlicemia" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreSPO2" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valorePeso" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreDiuresi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreAlvo" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <asp:DropDownList ID="valoreDieta" runat="server" CssClass="genericDropDownList" Width="290px" ><br /> <asp:ListItem Text="" Value=""></asp:ListItem><br /> <asp:ListItem Text="Vitto Normale" Value="1"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica I (1240 cal)" Value="2"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica II (1567 cal)" Value="3"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica III (2077 cal)" Value="4"></asp:ListItem><br /> <asp:ListItem Text="Dieta ipoproteica I senza zucchero; (1897 cal)" Value="5"></asp:ListItem><br /> <asp:ListItem Text="Dieta ipoproteica Il (2031 cal)" Value="6"></asp:ListItem><br /> <asp:ListItem Text="Dieta semiliquida" Value="7"></asp:ListItem><br /> <asp:ListItem Text="Dieta per diarroici in fase acuta (vitto senza secondi piatti)" Value="8"></asp:ListItem><br /> <asp:ListItem Text="Dieta di rialimentazione post-operatoria (vitto senza secondi piatti)" Value="9"></asp:ListItem><br /> <asp:ListItem Text="Dieta priva di glutine" Value="10"></asp:ListItem><br /> <asp:ListItem Text="Dieta pediatrica standard" Value="11"></asp:ListItem><br /> <asp:ListItem Text="Diete iposodiche" Value="12"></asp:ListItem><br /> <asp:ListItem Text="Diete personalizzate, supplementi" Value="13"></asp:ListItem><br /> <asp:ListItem Text="Dieta priva di lattosio" Value="14"></asp:ListItem><br /> <asp:ListItem Text="Digiuno" Value="15"></asp:ListItem><br /> </asp:DropDownList><br /> <ig:WebNumericEditor ID="valoreEmesi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreDrenaggio" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreCreatinina" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrazioneEiezione" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <br /> <asp:Label ID="unitaMisura_temperatura" runat="server" CssClass="genericLabel" Text=" °C " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_pMax" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_pMin" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_frequenzaCardiaca" runat="server" CssClass="genericLabel" Text=" bpm " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_frequenzaRespiratoria" runat="server" CssClass="genericLabel" Text=" apm " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_glicemia" runat="server" CssClass="genericLabel" Text=" mg/dl " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_saturazioneOssigeno" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_peso" runat="server" CssClass="genericLabel" Text=" kg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_diuresi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_alvo" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_emesi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_drenaggio" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_Creatinina" runat="server" CssClass="genericLabel" Text=" mg/dL " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_FrazioneEiezione" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /><br /> <br /> <asp:RequiredFieldValidator ID="valoreTemperaturaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreTemperatura" ValidationGroup="temperatura" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="pMaxRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMax" ValidationGroup="pressioneArteriosa" EnableViewState="False" /> <br /> <asp:RequiredFieldValidator ID="pMinRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMin" ValidationGroup="pressioneArteriosa" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrequenzaCardiacaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaCardiaca" ValidationGroup="frequenzaCardiaca" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrequenzaRespiratoriaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaRespiratoria" ValidationGroup="frequenzaRespiratoria" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreGlicemiaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreGlicemia" ValidationGroup="glicemia" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreSPO2RFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreSPO2" ValidationGroup="saturazioneOssigeno" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valorePesoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valorePeso" ValidationGroup="peso" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDiuresiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDiuresi" ValidationGroup="diuresi" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreAlvoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreAlvo" ValidationGroup="alvo" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDietaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text=" *" ControlToValidate="valoreDieta" ValidationGroup="dieta" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreEmesiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreEmesi" ValidationGroup="emesi" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDrenaggioRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDrenaggio" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreCreatininaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreCreatinina" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrazioneEiezioneRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrazioneEiezione" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <br /> <br /> <asp:CustomValidator ID="CustomValidator1" runat="server" ErrorMessage="Valore di Temperatura non e valida" forecolor="Red" ControlToValidate="valoreTemperatura" minimumvalue="25" maximumvalue="42" type="integer"></asp:CustomValidator><br /> <br /> </asp:Panel><asp:Panel ID="dynamicFields" runat="server" Visible="False"><br /> <asp:Label ID="label_valoreTemperatura" runat="server" CssClass="genericLabel" Text="Temperatura Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_pMax" runat="server" CssClass="genericLabel" Text="Pressione Sistolica Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_pMin" runat="server" CssClass="genericLabel" Text="Pressione Diastolica Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrequenzaCardiaca" runat="server" CssClass="genericLabel" Text="Frequenza Cardiaca Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrequenzaRespiratoria" runat="server" CssClass="genericLabel" Text="Frequenza Respiratoria Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreGlicemia" runat="server" CssClass="genericLabel" Text="Glicemia Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreSPO2" runat="server" CssClass="genericLabel" Text="SpO2 Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valorePeso" runat="server" CssClass="genericLabel" Text="Peso Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDiuresi" runat="server" CssClass="genericLabel" Text="Diuresi Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreAlvo" runat="server" CssClass="genericLabel" Text="Alvo Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDieta" runat="server" CssClass="genericLabel" Text="Dieta Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreEmesi" runat="server" CssClass="genericLabel" Text="Emesi Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDrenaggio" runat="server" CssClass="genericLabel" Text="Drenaggio Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreCreatinina" runat="server" CssClass="genericLabel" Text="Creatinina Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrazioneEiezione" runat="server" CssClass="genericLabel" Text="Frazione Eiezione Rilevato: " EnableViewState="False" /><br /><br /> <ig:WebNumericEditor ID="valoreTemperatura" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="pMax" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="pMin" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrequenzaCardiaca" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrequenzaRespiratoria" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreGlicemia" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreSPO2" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valorePeso" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreDiuresi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreAlvo" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <asp:DropDownList ID="valoreDieta" runat="server" CssClass="genericDropDownList" Width="290px" ><br /> <asp:ListItem Text="" Value=""></asp:ListItem><br /> <asp:ListItem Text="Vitto Normale" Value="1"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica I (1240 cal)" Value="2"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica II (1567 cal)" Value="3"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica III (2077 cal)" Value="4"></asp:ListItem><br /> <asp:ListItem Text="Dieta ipoproteica I senza zucchero; (1897 cal)" Value="5"></asp:ListItem><br /> <asp:ListItem Text="Dieta ipoproteica Il (2031 cal)" Value="6"></asp:ListItem><br /> <asp:ListItem Text="Dieta semiliquida" Value="7"></asp:ListItem><br /> <asp:ListItem Text="Dieta per diarroici in fase acuta (vitto senza secondi piatti)" Value="8"></asp:ListItem><br /> <asp:ListItem Text="Dieta di rialimentazione post-operatoria (vitto senza secondi piatti)" Value="9"></asp:ListItem><br /> <asp:ListItem Text="Dieta priva di glutine" Value="10"></asp:ListItem><br /> <asp:ListItem Text="Dieta pediatrica standard" Value="11"></asp:ListItem><br /> <asp:ListItem Text="Diete iposodiche" Value="12"></asp:ListItem><br /> <asp:ListItem Text="Diete personalizzate, supplementi" Value="13"></asp:ListItem><br /> <asp:ListItem Text="Dieta priva di lattosio" Value="14"></asp:ListItem><br /> <asp:ListItem Text="Digiuno" Value="15"></asp:ListItem><br /> </asp:DropDownList><br /> <ig:WebNumericEditor ID="valoreEmesi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreDrenaggio" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreCreatinina" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrazioneEiezione" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <br /> <asp:Label ID="unitaMisura_temperatura" runat="server" CssClass="genericLabel" Text=" °C " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_pMax" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_pMin" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_frequenzaCardiaca" runat="server" CssClass="genericLabel" Text=" bpm " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_frequenzaRespiratoria" runat="server" CssClass="genericLabel" Text=" apm " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_glicemia" runat="server" CssClass="genericLabel" Text=" mg/dl " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_saturazioneOssigeno" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_peso" runat="server" CssClass="genericLabel" Text=" kg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_diuresi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_alvo" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_emesi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_drenaggio" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_Creatinina" runat="server" CssClass="genericLabel" Text=" mg/dL " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_FrazioneEiezione" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /><br /> <br /> <asp:RequiredFieldValidator ID="valoreTemperaturaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreTemperatura" ValidationGroup="temperatura" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="pMaxRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMax" ValidationGroup="pressioneArteriosa" EnableViewState="False" /> <br /> <asp:RequiredFieldValidator ID="pMinRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMin" ValidationGroup="pressioneArteriosa" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrequenzaCardiacaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaCardiaca" ValidationGroup="frequenzaCardiaca" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrequenzaRespiratoriaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaRespiratoria" ValidationGroup="frequenzaRespiratoria" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreGlicemiaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreGlicemia" ValidationGroup="glicemia" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreSPO2RFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreSPO2" ValidationGroup="saturazioneOssigeno" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valorePesoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valorePeso" ValidationGroup="peso" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDiuresiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDiuresi" ValidationGroup="diuresi" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreAlvoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreAlvo" ValidationGroup="alvo" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDietaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text=" *" ControlToValidate="valoreDieta" ValidationGroup="dieta" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreEmesiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreEmesi" ValidationGroup="emesi" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDrenaggioRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDrenaggio" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreCreatininaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreCreatinina" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrazioneEiezioneRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrazioneEiezione" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <br /> <br /> <asp:CustomValidator ID="CustomValidator1" runat="server" ErrorMessage="Valore di Temperatura non e valida" forecolor="Red" ControlToValidate="valoreTemperatura" minimumvalue="25" maximumvalue="42" type="integer"></asp:CustomValidator><br /> <br /> </asp:Panel><asp:Panel ID="dynamicFields" runat="server" Visible="False"><br /> <asp:Label ID="label_valoreTemperatura" runat="server" CssClass="genericLabel" Text="Temperatura Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_pMax" runat="server" CssClass="genericLabel" Text="Pressione Sistolica Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_pMin" runat="server" CssClass="genericLabel" Text="Pressione Diastolica Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrequenzaCardiaca" runat="server" CssClass="genericLabel" Text="Frequenza Cardiaca Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrequenzaRespiratoria" runat="server" CssClass="genericLabel" Text="Frequenza Respiratoria Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreGlicemia" runat="server" CssClass="genericLabel" Text="Glicemia Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreSPO2" runat="server" CssClass="genericLabel" Text="SpO2 Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valorePeso" runat="server" CssClass="genericLabel" Text="Peso Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDiuresi" runat="server" CssClass="genericLabel" Text="Diuresi Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreAlvo" runat="server" CssClass="genericLabel" Text="Alvo Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDieta" runat="server" CssClass="genericLabel" Text="Dieta Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreEmesi" runat="server" CssClass="genericLabel" Text="Emesi Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreDrenaggio" runat="server" CssClass="genericLabel" Text="Drenaggio Rilevato: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreCreatinina" runat="server" CssClass="genericLabel" Text="Creatinina Rilevata: " EnableViewState="False" /><br /> <asp:Label ID="label_valoreFrazioneEiezione" runat="server" CssClass="genericLabel" Text="Frazione Eiezione Rilevato: " EnableViewState="False" /><br /><br /> <ig:WebNumericEditor ID="valoreTemperatura" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="pMax" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="pMin" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrequenzaCardiaca" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrequenzaRespiratoria" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreGlicemia" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreSPO2" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valorePeso" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreDiuresi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreAlvo" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <asp:DropDownList ID="valoreDieta" runat="server" CssClass="genericDropDownList" Width="290px" ><br /> <asp:ListItem Text="" Value=""></asp:ListItem><br /> <asp:ListItem Text="Vitto Normale" Value="1"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica I (1240 cal)" Value="2"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica II (1567 cal)" Value="3"></asp:ListItem><br /> <asp:ListItem Text="Dieta Ipoglicidica III (2077 cal)" Value="4"></asp:ListItem><br /> <asp:ListItem Text="Dieta ipoproteica I senza zucchero; (1897 cal)" Value="5"></asp:ListItem><br /> <asp:ListItem Text="Dieta ipoproteica Il (2031 cal)" Value="6"></asp:ListItem><br /> <asp:ListItem Text="Dieta semiliquida" Value="7"></asp:ListItem><br /> <asp:ListItem Text="Dieta per diarroici in fase acuta (vitto senza secondi piatti)" Value="8"></asp:ListItem><br /> <asp:ListItem Text="Dieta di rialimentazione post-operatoria (vitto senza secondi piatti)" Value="9"></asp:ListItem><br /> <asp:ListItem Text="Dieta priva di glutine" Value="10"></asp:ListItem><br /> <asp:ListItem Text="Dieta pediatrica standard" Value="11"></asp:ListItem><br /> <asp:ListItem Text="Diete iposodiche" Value="12"></asp:ListItem><br /> <asp:ListItem Text="Diete personalizzate, supplementi" Value="13"></asp:ListItem><br /> <asp:ListItem Text="Dieta priva di lattosio" Value="14"></asp:ListItem><br /> <asp:ListItem Text="Digiuno" Value="15"></asp:ListItem><br /> </asp:DropDownList><br /> <ig:WebNumericEditor ID="valoreEmesi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreDrenaggio" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreCreatinina" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <ig:WebNumericEditor ID="valoreFrazioneEiezione" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /><br /> <br /> <asp:Label ID="unitaMisura_temperatura" runat="server" CssClass="genericLabel" Text=" °C " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_pMax" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_pMin" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_frequenzaCardiaca" runat="server" CssClass="genericLabel" Text=" bpm " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_frequenzaRespiratoria" runat="server" CssClass="genericLabel" Text=" apm " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_glicemia" runat="server" CssClass="genericLabel" Text=" mg/dl " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_saturazioneOssigeno" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_peso" runat="server" CssClass="genericLabel" Text=" kg " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_diuresi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_alvo" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_emesi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_drenaggio" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_Creatinina" runat="server" CssClass="genericLabel" Text=" mg/dL " EnableViewState="False" /><br /> <asp:Label ID="unitaMisura_FrazioneEiezione" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /><br /> <br /> <asp:RequiredFieldValidator ID="valoreTemperaturaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreTemperatura" ValidationGroup="temperatura" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="pMaxRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMax" ValidationGroup="pressioneArteriosa" EnableViewState="False" /> <br /> <asp:RequiredFieldValidator ID="pMinRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMin" ValidationGroup="pressioneArteriosa" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrequenzaCardiacaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaCardiaca" ValidationGroup="frequenzaCardiaca" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrequenzaRespiratoriaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaRespiratoria" ValidationGroup="frequenzaRespiratoria" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreGlicemiaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreGlicemia" ValidationGroup="glicemia" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreSPO2RFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreSPO2" ValidationGroup="saturazioneOssigeno" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valorePesoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valorePeso" ValidationGroup="peso" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDiuresiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDiuresi" ValidationGroup="diuresi" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreAlvoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreAlvo" ValidationGroup="alvo" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDietaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text=" *" ControlToValidate="valoreDieta" ValidationGroup="dieta" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreEmesiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreEmesi" ValidationGroup="emesi" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreDrenaggioRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDrenaggio" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreCreatininaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreCreatinina" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <asp:RequiredFieldValidator ID="valoreFrazioneEiezioneRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrazioneEiezione" ValidationGroup="drenaggio" EnableViewState="False" /><br /> <br /> <br /> <asp:CustomValidator ID="CustomValidator1" runat="server" ErrorMessage="Valore di Temperatura non e valida" forecolor="Red" ControlToValidate="valoreTemperatura" minimumvalue="25" maximumvalue="42" type="integer"></asp:CustomValidator><br /> <br /> </asp:Panel><asp:Panel ID="dynamicFields" runat="server" Visible="False"> <asp:Label ID="label_valoreTemperatura" runat="server" CssClass="genericLabel" Text="Temperatura Rilevata: " EnableViewState="False" /> <asp:Label ID="label_pMax" runat="server" CssClass="genericLabel" Text="Pressione Sistolica Rilevata: " EnableViewState="False" /> <asp:Label ID="label_pMin" runat="server" CssClass="genericLabel" Text="Pressione Diastolica Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreFrequenzaCardiaca" runat="server" CssClass="genericLabel" Text="Frequenza Cardiaca Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreFrequenzaRespiratoria" runat="server" CssClass="genericLabel" Text="Frequenza Respiratoria Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreGlicemia" runat="server" CssClass="genericLabel" Text="Glicemia Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreSPO2" runat="server" CssClass="genericLabel" Text="SpO2 Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valorePeso" runat="server" CssClass="genericLabel" Text="Peso Rilevato: " EnableViewState="False" /> <asp:Label ID="label_valoreDiuresi" runat="server" CssClass="genericLabel" Text="Diuresi Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreAlvo" runat="server" CssClass="genericLabel" Text="Alvo Rilevato: " EnableViewState="False" /> <asp:Label ID="label_valoreDieta" runat="server" CssClass="genericLabel" Text="Dieta Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreEmesi" runat="server" CssClass="genericLabel" Text="Emesi Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreDrenaggio" runat="server" CssClass="genericLabel" Text="Drenaggio Rilevato: " EnableViewState="False" /> <asp:Label ID="label_valoreCreatinina" runat="server" CssClass="genericLabel" Text="Creatinina Rilevata: " EnableViewState="False" /> <asp:Label ID="label_valoreFrazioneEiezione" runat="server" CssClass="genericLabel" Text="Frazione Eiezione Rilevato: " EnableViewState="False" /> <ig:WebNumericEditor ID="valoreTemperatura" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="pMax" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="pMin" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreFrequenzaCardiaca" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreFrequenzaRespiratoria" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreGlicemia" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreSPO2" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valorePeso" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreDiuresi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreAlvo" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <asp:DropDownList ID="valoreDieta" runat="server" CssClass="genericDropDownList" Width="290px" > <asp:ListItem Text="" Value=""></asp:ListItem> <asp:ListItem Text="Vitto Normale" Value="1"></asp:ListItem> <asp:ListItem Text="Dieta Ipoglicidica I (1240 cal)" Value="2"></asp:ListItem> <asp:ListItem Text="Dieta Ipoglicidica II (1567 cal)" Value="3"></asp:ListItem> <asp:ListItem Text="Dieta Ipoglicidica III (2077 cal)" Value="4"></asp:ListItem> <asp:ListItem Text="Dieta ipoproteica I senza zucchero; (1897 cal)" Value="5"></asp:ListItem> <asp:ListItem Text="Dieta ipoproteica Il (2031 cal)" Value="6"></asp:ListItem> <asp:ListItem Text="Dieta semiliquida" Value="7"></asp:ListItem> <asp:ListItem Text="Dieta per diarroici in fase acuta (vitto senza secondi piatti)" Value="8"></asp:ListItem> <asp:ListItem Text="Dieta di rialimentazione post-operatoria (vitto senza secondi piatti)" Value="9"></asp:ListItem> <asp:ListItem Text="Dieta priva di glutine" Value="10"></asp:ListItem> <asp:ListItem Text="Dieta pediatrica standard" Value="11"></asp:ListItem> <asp:ListItem Text="Diete iposodiche" Value="12"></asp:ListItem> <asp:ListItem Text="Diete personalizzate, supplementi" Value="13"></asp:ListItem> <asp:ListItem Text="Dieta priva di lattosio" Value="14"></asp:ListItem> <asp:ListItem Text="Digiuno" Value="15"></asp:ListItem> </asp:DropDownList> <ig:WebNumericEditor ID="valoreEmesi" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreDrenaggio" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreCreatinina" DataMode="Int" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <ig:WebNumericEditor ID="valoreFrazioneEiezione" DataMode="Float" runat="server" CssClass="infragisticsWebNumericEditor" EnableViewState="False" /> <asp:Label ID="unitaMisura_temperatura" runat="server" CssClass="genericLabel" Text=" °C " EnableViewState="False" /> <asp:Label ID="unitaMisura_pMax" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /> <asp:Label ID="unitaMisura_pMin" runat="server" CssClass="genericLabel" Text=" mmHg " EnableViewState="False" /> <asp:Label ID="unitaMisura_frequenzaCardiaca" runat="server" CssClass="genericLabel" Text=" bpm " EnableViewState="False" /> <asp:Label ID="unitaMisura_frequenzaRespiratoria" runat="server" CssClass="genericLabel" Text=" apm " EnableViewState="False" /> <asp:Label ID="unitaMisura_glicemia" runat="server" CssClass="genericLabel" Text=" mg/dl " EnableViewState="False" /> <asp:Label ID="unitaMisura_saturazioneOssigeno" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /> <asp:Label ID="unitaMisura_peso" runat="server" CssClass="genericLabel" Text=" kg " EnableViewState="False" /> <asp:Label ID="unitaMisura_diuresi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /> <asp:Label ID="unitaMisura_alvo" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /> <asp:Label ID="unitaMisura_emesi" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /> <asp:Label ID="unitaMisura_drenaggio" runat="server" CssClass="genericLabel" Text=" ml " EnableViewState="False" /> <asp:Label ID="unitaMisura_Creatinina" runat="server" CssClass="genericLabel" Text=" mg/dL " EnableViewState="False" /> <asp:Label ID="unitaMisura_FrazioneEiezione" runat="server" CssClass="genericLabel" Text=" % " EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreTemperaturaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreTemperatura" ValidationGroup="temperatura" EnableViewState="False" /> <asp:RequiredFieldValidator ID="pMaxRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMax" ValidationGroup="pressioneArteriosa" EnableViewState="False" /> <asp:RequiredFieldValidator ID="pMinRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="pMin" ValidationGroup="pressioneArteriosa" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreFrequenzaCardiacaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaCardiaca" ValidationGroup="frequenzaCardiaca" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreFrequenzaRespiratoriaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrequenzaRespiratoria" ValidationGroup="frequenzaRespiratoria" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreGlicemiaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreGlicemia" ValidationGroup="glicemia" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreSPO2RFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreSPO2" ValidationGroup="saturazioneOssigeno" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valorePesoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valorePeso" ValidationGroup="peso" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreDiuresiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDiuresi" ValidationGroup="diuresi" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreAlvoRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreAlvo" ValidationGroup="alvo" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreDietaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text=" *" ControlToValidate="valoreDieta" ValidationGroup="dieta" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreEmesiRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreEmesi" ValidationGroup="emesi" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreDrenaggioRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreDrenaggio" ValidationGroup="drenaggio" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreCreatininaRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreCreatinina" ValidationGroup="drenaggio" EnableViewState="False" /> <asp:RequiredFieldValidator ID="valoreFrazioneEiezioneRFV" runat="server" CssClass="RequiredFieldValidatorStyle" Text="*" ControlToValidate="valoreFrazioneEiezione" ValidationGroup="drenaggio" EnableViewState="False" /> <asp:CustomValidator ID="CustomValidator1" runat="server" ErrorMessage="Valore di Temperatura non e valida" forecolor="Red" ControlToValidate="valoreTemperatura" minimumvalue="25" maximumvalue="42" type="integer"></asp:CustomValidator> </asp:Panel>
..............................can anyone help me please i am in hurry!!!!!!!
AND ALSO THANK YOU!!!!!!
Hi Tarja,
Attached is a small sample with two WebNumericEditors and RequiredFieldValidators in a validation group. When the button is clicked and one or both of them is empty the validation is triggered and the error message is displayed.
4382.NumericEditorSample.zip
