115
Dropdownprovider validation
I need to add validation for all the dropdownprovider inside the WebDatagrid like if the DropdownProvider default value ' --Choose Product--' not changed to any product from the list.Then validation should occur.
rakesh
  • 1320
    Hello Rakesh,
    After investigating this further, I determined that your requirement could be achieved by adding a RequiredFieldValidator the following way:
    <ig:WebDataGrid ID=”wdg”>
    </ig:WebDataGrid>
    <asp:RequiredFieldValidator ID="Validator1" Text="Item is required" runat="server" ControlToValidate="wdg"></asp:RequiredFieldValidator>
    A ValidatorId should also be added to the column, which is bound to the dropDown provider:
    <ig:CellEditing >
        <ColumnSettings>
              <ig:EditingColumnSetting ColumnKey="DropDown1" EditorID="wdg_DropDownProvider1" ValidatorID="Validator1" />
         </ColumnSettings>
    </ig:CellEditing>
    In order for this to work jQuery scripts should be added in the file and in the web.config in the configuration tag the following lines of code:
    <appSettings>
        <add key="ValidationSettings:UnobtrusiveValidationMode" value="None" />
    </appSettings>
    Below I am attaching a sample demonstrating how this could be achieved. Please test it on your side and let me know if you need additional information regarding this matter.
    Monika Kirkova,
    WebDataGridDropDownProvider.zip
