Hi I just installed infragistics sdk and the other executables in the package but for some reason i cannot find the images folder that should be with the package.
The reason i need the images is that I am try to implement a UltraChart for a column chart for my web application and apparantly it needs sone chart png's for it to work
If you are trying to get the images for the scrollbars in an UltraChart, then you must drag on a UltraChart to your design surface and set EnableScrollbars to true. This will generate the appropriate scrollbar images in the ChartImages folder.
If you are experiencing a different issue could you give more detail.
