190
Populate Values on the Next Cell Based on Page Method Success function in web Data Grid
Hi, i have Implemenrtted Web Data Grid and on One Value , Request is sending to the Server , Getting Record Against that Value (this is Working FIne). and Need to populate the Data on Next Cell, which is not Populating.
My Code is :
function KeyDown(sender, eventArgs) {
sender = sender;
rowsCount = sender.get_rows().get_length();
columnsCount = sender.get_columns().get_length();
rowIndex = sender.get_behaviors().get_activation().get_activeCell().get_row().get_index();
fromLastColumn = sender.get_behaviors().get_activation().get_activeCell().get_column().get_index();
var keyCode = eventArgs.get_browserEvent().keyCode;
var newActiveCell;
if (keyCode == 9)
var grid = getGridByID('<%=grdDetail1.ClientID%>');
grid.get_behaviors().get_selection().get_selectedRows().add(grid.get_rows().get_row(0));
var a = grid.get_behaviors().get_activation().get_activeCell().get_row().get_cellByColumnKey("tax_number")
var usingRowSelection = a.get_text()
NextColumn = grid.get_behaviors().get_activation().get_activeCell().get_row().get_cellByColumnKey("Name");
console.log("NextColumn In KeyDown" + " " + NextColumn)
GetDetailByTax_NumberOnNextKin(usingRowSelection)
setTimeout(function () {
//alert("hi")
//alert(document.getElementById('hfName').value);
console.log(document.getElementById('hfName').value);
NextColumn.set_value(document.getElementById('hfName').value);
console.log("i am Executed");
}, 1000);
//var rowsCount = sender.get_rows().get_length();
//var columnsCount = sender.get_columns().get_length();
//var rowIndex = sender.get_behaviors().get_activation().get_activeCell().get_row().get_index();
//var fromLastColumn = sender.get_behaviors().get_activation().get_activeCell().get_column().get_index();
//var keyCode = eventArgs.get_browserEvent().keyCode;
//var newActiveCell;
//if (keyCode == 9) {
// if ((rowIndex + 1) === rowsCount) {
// if (fromLastColumn === 0) {
// newActiveCell = sender.get_rows().get_row(rowIndex).get_cell(currentCellColumnIndex);
// } else {
// if ((currentCellColumnIndex + 1) === columnsCount) { //for the last column
// newActiveCell = sender.get_rows().get_row(0).get_cell(0);
// currentCellColumnIndex = 0;
// } else {
// newActiveCell = sender.get_rows().get_row(0).get_cell(++currentCellColumnIndex);
// } else {
// } else {
// newActiveCell = sender.get_rows().get_row(rowIndex + 1).get_cell(currentCellColumnIndex);
// sender.get_behaviors().get_activation().set_activeCell(newActiveCell);
function GetDetailByTax_NumberOnNextKin(obj) {
PageMethods.GetDetailByTax_Number(obj, OnNextKinSuccess);
function OnNextKinSuccess(data) {
debugger
if (data != null || data != "") {
NextColumn.set_value(data);
document.getElementById('hfName').value = data;
//var cell = grid.get_rows().get_row(0).get_cell(1);
//grid.get_behaviors().get_activation().set_activeCell(cell);
// Get active cell
//var activeCell = grid.get_behaviors().get_activation().get_activeCell();
// var cell = grid.get_behaviors().get_activation().get_activeCell().get_row(0);
// grid.get_behaviors().get_activation().set_activeCell(cell);
//if (fromLastColumn === 0) {
// newActiveCell = grid.get_rows().get_row(rowIndex).get_cell(currentCellColumnIndex);
//} else {
// newActiveCell = grid.get_rows().get_row(0).get_cell(0);
// } else {
// newActiveCell = grid.get_rows().get_row(0).get_cell(++currentCellColumnIndex);
} else {
} else {
newActiveCell = grid.get_rows().get_row(rowIndex + 1).get_cell(currentCellColumnIndex);
  • 1080
    Since there are missing pieces like the code-behind and how WebDataGrid is defined, I have created and attached a small sample with cascading WebDropDown in WebDataGrid which demonstrates retrieving of data for the next cell based on the current one.
    Please take a look at it and let me know whether it helps you to achieve your requirement. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me for further investigation.
    5822.Sample.zip
