'm using UltraWebCharts to plot Gantt chart in my Web form.
I have few queries regarding this controls:
1. Is it possible to move X-Axis position? Currently its at bottom of the chart, I need to move it to the top.
2. Bottom Title and X-axis labels are overlaping. Ho to resolve it?
Hello Harjot,
I am glad that you find my suggestion helpful and were able to solve your issue.
Regards, Monika Kirkova, Infragistics
Thanks Monika Kirkova.
It is working
After investigating this further, I determined that the x-axis could be positioned to the top of the chart by hiding the x-axis and displaying x2-axis. This could be achieved from the quick design of the Gantt chart in the Axis group of the explorer bar:
The code in the Default.aspx would look as follows:
<igchart:UltraChart ID="UltraChart1" runat="server" ChartType="GanttChart" . . . >
<Axis>
<X Visible="false" TickmarkInterval="0">
<Labels ItemFormatString="<ITEM_LABEL:MM-dd-yy>oooooooooooooo" Visible="True" FontColor="" HorizontalAlign="Near" VerticalAlign="Center" Orientation="VerticalLeftFacing">
</Labels>
</X>
<X2 Visible="true" TickmarkInterval="0">
</X2>
</Axis>
Regarding your second requirement, the margins of the x axis and x2 axis could be modified, in order to change the horizontal position of the chart.
<Margin>
<Far Value="25.362318840579711" />
</Margin>
Below I am attaching a sample, demonstrating the described behavior. Please test it on your side and let me if you need any further information regarding this matter.
WebChartGanttChart.zip
