Taking a shot in the dark...I know this is an old, unsupported version and control but I am so close to getting this huge application working in Google Chrome I just have to give it a shot. So right now the app works fine in IE but some nodes do NOT trigger a load event in Google Chrome; I dug into the JS files and I think I have a fix but no matter what I change, nothing changes. So I think this version uses the web resources and therefore the scripts are compiled in the DLLs right? So that is a dead end. BUT is there a way to disable the web resources or just point the app or the control to a script directory or a new ig_webtree.js file? I hope so.
Can anyone help?
Hi Peter,
I am glad that you managed to achieve your requirement.
Thank you for choosing Infragistics!
Yes...this seems to be working...awesome...thanks for your help.
Exactly, this sounds like the way to go. Do not hesitate to contact us at any time if any issue occurs or just to let us know if this worked in the end.
So instead of continuously fixing each function I may or may not discover not working, I went ahead and copied the entire file and tweaked all instances of the case sensitivity issue and am overwriting all the functions...so far this seems to be working...will continue testing. I can't thank you enough for your help.
Check what is passed as node in the function arguments, check node.element.childNodes, compare it with a browser where this is working to see whats the difference. Keep us posted on the progress
