I am having a problem binding WebExplorerBar to WebHierarchicalDataSource and ObjectDataSource, below follow the html code.
I have 2 tables related with each other. Curso table with 3 records and Serie table with some records related to table Curso by idCurso foreign key.
WebExplorerBar shows the 3 Curso records as groups as expected but the problem is that it's only expanding the first group showing Serie related records, but the second and third group does not expands to show Serie related records. I have already verified and all the records from Serie table are being retrieved from database and all the 3 records from Curso has related records from Serie.
Here is the code.
<ig:WebExplorerBar ID="WebExplorerMenu" runat="server" Width="100%" Visible="true" DataSourceID="ExplorerBarHierarchicalDataSource" GroupExpandBehavior="AnyExpandable" BackColor="White" InitialDataBindDepth="0"> <DataBindings> <ig:ExplorerBarItemBinding DataMember="Grupos" TextField="NomeCurso"/> <ig:ExplorerBarItemBinding DataMember="Items" TextField="NomeSerie"/> </DataBindings> </ig:WebExplorerBar>
<ig:WebHierarchicalDataSource ID="ExplorerBarHierarchicalDataSource" runat="server"> <DataViews> <ig:DataView DataSourceID="ObjectDataSourceGrupo" ID="Grupos" /> <ig:DataView DataSourceID="ObjectDataSourceItem" ID="Items" /> </DataViews> <DataRelations> <ig:DataRelation ParentDataViewID="Grupos" ParentColumns="idCurso" ChildDataViewID="Items" ChildColumns="idCurso"/> </DataRelations> </ig:WebHierarchicalDataSource> <asp:ObjectDataSource ID="ObjectDataSourceGrupo" runat="server" SelectMethod="GetCursos" TypeName="WintechNetEscola.Controllers.Views.Views"> </asp:ObjectDataSource> <asp:ObjectDataSource ID="ObjectDataSourceItem" runat="server" SelectMethod="GetSeries" TypeName="WintechNetEscola.Controllers.Views.Views"> </asp:ObjectDataSource>
Hello Edson,
I’m glad that you were able to resolve your issue.
Thank for choosing Infragistics!
Regards, Ivan Kitanov
Thanks for the quick response and I found the problem.
The methods that retrieves data from database return IQueryable<> and I change them to return IList<>.
This small change solve the problem and WebExplorerBar starts working as expected.
The provided HTML seems correct to me and I’m not able to point out the cause of the issue. In order to investigate your issue further, is it possible to provide me a small isolated sample that reproduces it? Remove any external dependencies and code that is not directly related to the issue, zip your application and attach it in.
Having a working sample on my side, which I can test and debug, is going to be very helpful in finding the root cause of this behavior.
Thank you for your cooperation.
