35
Select option doesn't work
Selecting option doesn't work inside WebExplorerBar.
<ig:WebExplorerBar ID="WebExplorerBar1" runat="server" GroupExpandBehavior="AnyExpandable" AutoPostBackFlags-ItemClick="Off" >
<Groups>
<ig:ExplorerBarGroup>
<Items>
<ig:ExplorerBarItem Text="foo">
<Template>
<select id="selectElement" size="3">
<option value="">Select an option</option>
<option value="Option 1">Option 1</option>
<option value="Option 2">Option 2</option>
<option value="Option 3">Option 3</option>
</select>
</Template>
</ig:ExplorerBarItem>
</Items>
</ig:ExplorerBarGroup>
</Groups>
</ig:WebExplorerBar>
  • 1700
    Hello Assaduz,
    I’ve tested this out, on my side the select element works as expected. The select is displayed with the correct size that has been set in the markup and the value is retained when expanding/collapsing the dropdown of the ExplorerBarGroup, the value is retained.
    Alternatively, if the size property is not set the select could be opened through the dropdown arrow and the selected value is still retained when expanding/collapsing the dropdown of the ExplorerBarGroup.
    I am attaching two gifs that demonstrate the behavior of the select element inside the WebExplorerBar:
    Please let me know if the behavior is different on your side or if you need any further assistance.
    Ivan Kitanov
