1470
Patched to 22.2.20222.86 issue with Infragistics45.WebUI.Shared.v22.2
After patching to SR 86., getting the error: The project currently contains references to more than one version of 'Infragistics45.WebUI.Shared.v22.2', a direct reference to version 22.2.20222.17 and an indirect reference to version 22.2.20222.86. Change the direct reference to use version 22.2.20222.86 (or higher) of Infragistics45.WebUI.Shared.v22.2.
Infragistics45.WebUI.Shared.v22.2.dll is still on 22.2.20222.17, should this file be updated to 22.2.20222.86?
Is there an updated Infragistics45.WebUI.Shared.v22.2.dll?
  • 1700
    Hello Pete,
    Could you make sure that there is only one reference of the Infragistics45.WebUI.Shared DLL in the references section of the solution explorer?
    If there is a single reference of all the Infragistics DLLs that are from the version of the service release, could you please check the DLLs inside the bin folder to see if there are any duplicates and remove the duplicates leaving the ones that match the correct service release version?
    If the suggested approaches don’t help, please try to use the Version Utility with the “Website” option, it would automatically replace all the Infragistics DLLs to the latest version installed.
    Please let me know if you need any further assistance.
    Ivan Kitanov
