I am installing ASP.NET 2008 volume 2 on Vista.
The following tools do not appear in my toolbox:
WebDialogWindow
WebHierarchicalDataSource
WebImageViewer
WebResizingExtender
WebSlider
WebSplitter
Everything else installs fine.
Thanks.
Vince, it works. I had the same problem with Vista/VS2005. The web slider control was not available. After the installation of the AJAX Toolkit 1.0 for ASP 2.0 and run again the tool "Create Visual Studio Toolbox Tab", the control was available. Thank you.
An additional thought: If you're using Visual Studio 2005, you'll also need to install Microsoft ASP.NET AJAX Extensions. An installer for an early RTM version of these extensions is included in the same location to where you installed the NetAdvantage for .NET toolset.
If you're using Visual Studio 2008, this extra step shouldn't be necessary. VS2008 includes what was in the ASP.NET AJAX Extensions for VS2005.
