I have an application which depending on business rules might have a single or multiple images.
If there are multiple images everything works fine. However if there is a single image, if you click on the next prev button or attempt to drag the image produces a javascript error. (I have resolved this issue by disabling the next, prev button and also dragging capability), but shouldn't this be native to the imageviewer?
In addition if there is only 1 image avaiable it looks like its not centered in the webimageviewer.
How can I address those issues?
Valentin
Hello Martyn,
It should be there, in the upcomming hotfix release.
Hope this helps,
I am currently running version 20082.2022 and i am also getting an error when the Image Viewer only has a single image. I too have disabled the next and previous buttons along with the EnableDragScrolling but using the Mouse Scroll wheel causes an error in the .axd code.
Can you please confirm this has also been addressed in the next release/hotfix and also when this might be released?
Kind Regards,
Martyn...
Hi Valetin,
We have addressed this issue and it will be fixed in the next realease and/or Hotfix that will be availiable.
