Whenever I try to drop a NetAdvantage control on a VS2008 ASP.NET web form, I get the following error...
The operation could not be completed. Invalid FORMATETC structure
Standard Microsoft ASP controls work fine. Any ideas on how to correct this?
I also had this problem. I had been running VS2008 with IG 2008 vol 2 without problems, but started getting the above error after installing an IG hotfix. Manually deleting the IG controls tab in VS2008 and running the IG utility to install the controls into VS resolved the issue.
ChuckProCare Rx
I have the same error... but it work now. My web.config was on "read only".
hm, I have the same error. And adding the controls manually, didnt solve the problem either....
I did the same. Unchecked them and rechecked them too.
Ryan
I added all the controls manually by selecting the check boxes.
