Hi all,
I am using Infragistic controls but I dont have WebSplitter control in my toolbox.
How would I get that.
kindly help.
Hi Sir,
Me got the same problem and here's the scenario:
First i successfully used wesplitter an added on my webforms (ajax enabled). but during the course of my prototyping, .net gave me an error somehow GAC is pointing to 2 version of the object one is for 2.0 and 3.5 during buildMy collegues adviced me to remove .net framework 3.5 instead and did it. but when i tried to re-open the project again, i can't find infragistics websplitter object anymore. i tried re-installing the NetAdvantage over and over but still all went in vain. I'm thinking this is due to garbage installation i've made so i tried installing netadvantage to my laptop and i was freaking out coz all components successfully installed other than websplitter. :( pls help sir. what should i do. What differs websplitter from other component and face this kind of confusion.
Appreciate your prompt reply. TY in advance.
Thanks for your interest in our products and for dropping us a line. WebSplitter (and in fact all new controls that we shipped in our 2008.1 and 2008.2 releases) are located in the new assembly, called Infragistics35.Web.v8.2.
If you have run the installer, it should have successfully added these for you already, but if not, please locate the assembly (Infragistics35.Web.v8.2 for 2008.2 and Infragistics35.Web.v8.1 for 2008.1) and add it manually to your toolbox (right click on the toolbar, select choose items and navigate to the assembly).
In my opinion it is best to run the installer, since it installs in GAC (global assembly cache) and adds all needed prerequisites
Please, let me know if you encounter any problems with that.
