Hi All,
After I installed windows forms 2008 Vol.1(also 2007 Vol. 3), the samples can't be found anywhere, but for 2006 Vol. 3, there are samples in Start->Infragistics...
Additionally, is there online samples available?
With appreciation for help in advance!
Alfonzoe
http://ko.infragistics.com/dotnet/netadvantage.aspx#Downloads
Samples are installed as part of the SDK.
When you hover over each of the links on the download page it should describe what is in each install.
If you've run the SDK install and can't find the start menu link please contact support via the Ask for help page and they may be able to find the solution as to why the samples aren't appearing on your machine.
http://ko.infragistics.com/support/ask-for-help.aspx#AskforHelp
