755
Setting name property of iframe created by splitterpane
I use a websplitter. I set the ContentUrl of one of the splitterpanes. The other splitter pane contains html links, I want to target the html links to use the splitterpane. However the iframe rendered by the SplitterPane does not render a name attribute. Therefore my anchors cannot target the iframe.
  • 5
    A nice hack for this is to set the contenturl in the aspx page - but then remove it on load and add a control that contains the iframe
    protected void Page_Load(object sender, EventArgs e)
    AddIdToSplitterPanelIFrame(wsMainContent.Panes[0]);
    private void AddIdToSplitterPanelIFrame(Infragistics.Web.UI.LayoutControls.SplitterPane pane)
    if (!String.IsNullOrEmpty(pane.ContentUrl))
    string id = pane.ClientID;if (id.EndsWith(pane.ID))
    id = id.TrimEnd(pane.ID.ToCharArray()) +
    "iframe";
    string contentUrl = pane.ContentUrl;
    pane.ContentUrl = String.Empty;
    Literal lb = new Literal();
    lb.Text = "<iframe src='" + contentUrl + "' id='" + id + "' style='width:100%;height:100%;'></iframe>";
    pane.Controls.Add(lb);
    then you can get the id within the javascript via
    <script type="text/javascript" language="javascript">
    function goto(url)
    document.getElementById(
    '<%= wsMainContent.Panes[0].ClientID.TrimEnd(wsMainContent.Panes[0].ID.ToCharArray()) + "iframe" %>').src = url;
    </script>
    works for me - but obviously a dirty dirty hack - much better if the control had a ControlFrameId property that did that for you
