325
Turn off Modify Image right click?
Is there a property to turn off the right click modify image menu item when you right click an image?
  • 24497
    There is no property. You have 2 options:
    1. remove InsertImage from RightClickMenu (line similar to)
    <ighedit:HtmlBoxMenuItem runat="server" Act="InsertImage"></ighedit:HtmlBoxMenuItem>
    2. process ClientSideEvents.BeforeAction and cancel action which happens on that particular event. Below is example to implement.
    function
    WebHtmlEditor1_BeforeAction(oEditor, actID, oEvent, p4, p5, p6, p7, p8, act)
    if(actID != 'RightClick' || act != 'pop') return;
    // next block is optional
    if(p6)
    var src = p6.srcElement;
    if(!src)
        src = src.target;
    if(src && src.nodeName != 'IMG')
    return;
     oEvent.cancel =
    true;
    </script>
