Hello,I basically have 10 chart that shows the sales result of top 10 companies. The sql query is the same for each one them except for the companyid which is the parameter.Unfortunately it always shows the same data for the 10 charts and this is the data for the last chart.I manually change the paramter "companyid" and then force the chart to databind but I am still getting the same data on each chart.Any idea of how I could do that without creating 10 sqldatasource?Thanks
Yes, if you are using one datasource object, at the end of creating the page you'll have same data for each chart. This is happening because we are initializing the data depending on the datasource in the Render event of the page and at this moment that data is the same. In your case you probably need to created different datasource objects for each chart.
