In my .Net 3.5 web application, the compiler gives there messages:
1. Could not find schema information for the element 'infragistics.web'
2. Could not find schema information for the attribute 'styleSetName'
3. Could not find schema information for the attribute 'styleSetPath'.
A section of my web.config file is below.
How do I elimnate these messages. When trying to publish the app, they prevent success.
<section name="infragistics.web" type="System.Configuration.SingleTagSectionHandler,System, Version=1.0.3300.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<sectionGroup name="scripting" type="System.Web.Configuration.ScriptingSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35">
<sectionGroup name="webServices" type="System.Web.Configuration.ScriptingWebServicesSectionGroup, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35">
<section name="profileService" type="System.Web.Configuration.ScriptingProfileServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="MachineToApplication" />
<section name="roleService" type="System.Web.Configuration.ScriptingRoleServiceSection, System.Web.Extensions, Version=3.5.0.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35" requirePermission="false" allowDefinition="MachineToApplication" />
</sectionGroup>
</configSections>
<infragistics.web styleSetName="Default" styleSetPath="~/ig_res" />
I resolved this by rebuilding the web.config file from scratch.
Thank you.
I am having a serious problem that is very similar! I need a fix ASAP! I am getting sick & tired of posting & waiting.
I am getting the warnings that
I am using VS2008 (with SP1). The project is set to target .NET 3.5 Framework. And I have included infragistics35.web.v10.2 as a reference.
The line in the web.config file is below:
I need help.
You should add a reference to Infragistics.Web in your project.
I am having the same problem. I get the following message when I compile.
Could not find schema information for the element 'infragistics.web'. web.config 11 4
I have the project compiling correctly under an older version of Infragistics on another computer. I installed NetAdvantage ASP.NET 2008 Vol 2 on this computer and then downloaded the project from SourceSafe.
I upgraded the project using the 'Project Upgrade Utility' and now have this error.
It's the web.config built as I added the controls to a web page. I'll try your suggestion and see what happens. Thanks.
