40
WHDS not in my toolbox
i´m using NetAdvantage for .NET 2008 Vol. 2 CLR 2.0 (Version 8.2?!) with Vista and VS 2008.
I cannot see the WHDS in my toolbox.
What can i do to see the WHDS in my toolbox?
  • 150
    Hello stitchac
    Did you try to run the Toolbox utility located in the Start menu under the Infragistics folder ?
    Another way is to locate the folder where the IG assemblies are installed and drag nd drop them in the tollbox under the desired tab.
    Third way is to expand the tab you want to have the WHDS in, right click | Choose Items | Browse | navigate directory where the files are located and select Infragistics2.Web.UI.v8.2.dll and then select the desired controls. WebHierarchicalDatasource should be there.
    If you need more help do not hesitate to contact us.
    Thanks Christo Djambov
