349
InitilizeScrollbar Error on displaying Webchart
 Hello
I am currently having a problem with a WebChart, where each time I try to display the chart after using the databind method, the following error message appears
InitilizeScrollbar is not defined
The script that contains the InitilizeScrollbar method call is generated on the aspx file after the Page has finished loading.
The WebChart had been recently upgraded from 2007 Vol 2 to 2008 Vol 2 and uses the Webresource.axd file instead of Javascript. Any solution to the problem would be appreciated.
Regards
Adam Faulkner
Croner Software
